yeah liuzzi flying backwards over the ripple strip was pretty hairy. the safety car did well to avoid that one! I don't think I've ever seen an F1 car collect a safety car before. and hamilton was VERY lucky not to have his big mac cleaned up by albers when he came steaming into the gravel.
  • Replies 2.1k
Posted Images
yeah i agree. he was fast and passing lots of cars, but they were all pretty average cars and often he was on the better tyre at the time when he was moving forward. he made quite a few errors.
Also am I the only one surprised that alonso (or more accurately Mclaren) didn't get penalised for the way he left his pit box straight into the path of another car?
id like to see you stand there when the car is launching toward you and just misses you by inches.
id be rightly pissed and looking for a head or two to roll..
im not out there to get my legs amputated by a hotheaded spaniard..
F1 drivers arent exactly the smartest chaps in the world are they??
that arguement seemed oddly reminiscent of an Irvine senna battle a few years ago...
yeah, with him still sitting in the thing...
how he managed to get out of that is very lucky. WTF were the drivers carrying so much speed into turn one for in the first place??
"christian, there are 3 cars in the kitty litter at turn one. Please slow down and watch yourself, its very easy to aquaplane out there.."
"okey, no probleem, ill keep pusheeng!"
( now stuck in the litter )
"guys im reeely sorry for dis.. I didnt understand what you said. I need some more english practice i theenk."
yeah I would complain too. it was a bullshit decision by his pit crew to release him, and a bad one on his part not to give way to the car in the fast lane.
lol, albers was flying towards lewey. lewis certainly has some bloody good luck. cheeky little bugger.
I am just so pleased webber got a good result. it should help his career along a bit. he drove very well and kept it on the track and most importantly kept everyone else behind him. it shows for sure that he was a good driver in a poor car that he was over a minute behind second place yet still managed to keep everyone else (what was left of them) behind him.
You know what. Watching Alonso last night...he is brilliant. I do feel for Massa though. He ran well and then the rain? Well it looks like he just didnt have the tyres/car to finish the job he had been doing all day.
But again, not a fan of Alonso, but you have to sit back and respect that he is bloody good.
yeah alonso drove a good race. but how girly was his little fist punching standing in front of the podium. it was like he was a 12 year old girl in a punch up with his little arms flailing around. maybe he should go back to his animal impressions? give me schueys leap any day.
lol, at least we can all agree on that!
and massa is a bit of a man-girl as well. sure he can pick fights with gonzo but I'd like to see one of them start a fight with coulthard, or montoya...
I just watched on the News that next years Formula 1 in melbourne WILL have a later start. I dont know how late this is, and whether its night but I hope it is!!
Also V8 supercars are back next year.
Can anyone confirm on next years late start?
Massa being brazillian aside, i see your point, and i LOL'd
hmm, yeah that was a bit flawed. but in my defense i'll say that though he may have been born in brazil, if it looks like a euro fag, talks like a euro fag, acts like a euro fag and smells like a euro fag then let's just call it euro fag. sorry massa.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
