  • Replies 2.1k
Posted Images
this is absolutely hilarious!
guess which country made the video...
http://www.youtube.com/watch?v=vINtUt2hV90
That was pretty funny for about 30 seconds.... the rest got a bit monotonous.
GO WEBBER!
Might even make it out to the crown tonight and watch it on the big screen, and drop a couple of bucks on Webbo to boot. (Each way of course)
Missed qualifying despite tryign to stay up for it. I read that LH aplogised for holding up Kimi in qualifying!!!! LOL, his good fortune conitunes, Hopefully he is silly enough to try an drace Massa and Massa punts him out of the race.
you want to see quali roy? im hookin it up right now...
McLaren suck. How can they choke so badly in the tale end of the series. it seems with all the competition amongst their drivers they may have forgotten about Kimi. Hats off to the guy, his manager got it right. He keeps his mouth shut and gets the results. Most wins and most deserving winner!
Now off to enjoy reading about how Alonso ruined LH/s rave by actually racing him on the first lap....Louise will no doubt be hardened by the disappointment and will likely not drop the ball again in the future.
Alos, hats off to Massa. Did the perfect sidekick job to do his part for the team. No doubt disappointed himself...but drove a solid race ad no doubt was on for a win, proving why he just got a new contract
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
