  • Replies 161
Whiteline has a suspension package for the GTiR that is very helpful for that understeering issue.. Also, it would help if you got rid of the stocky 14 inch wheels.
As for the 4wd system... they are supposed to be the same as the Bluebird SSS which uses the Atessa (spelling) system.
It IS FWD until it loses traction and sends torque to the rears (sort of opposite to the gtr)
Originally posted by Big Dave
My brother has a GTIr , we raced a black GTST out at the illegal drags all the pulsar has is an exaust and a air filter , the GTST had a frount mount i think and a exaust from the turbo back and the pulsar got about 6 car lengths off the mark untill , the skyline owner wanted a rolling run, still the pulsar got about 3 car lengths, the skyline had Queensland plates as well!!!!!:eek:
hahah amust of been donnie.
ptsssssss nothing beats a skyline
simple
gti-rs to me are like mini wannabe gt-rs
2 less cylinders 1 less turbo
yeh but if u get an r32 and do it up for the same price as a gti-r it'll eat it alive
gti-rs too me are a rip off
if your talking about speed u can buy a 12 sec torana for 6 grand ffs!
its wat u like and wat ur looking for
i personally will go for the skyline as it has heaps more potential.
actually i saw an r32 gtr stock with exhaust and mags vs a gtir turbo exhaust and some minor modifications get ****ed up by like 8 cars lengths of the mark and then at the end it got to like 6 car lengths and the guys in the pulsar excuse was that the car bogged on take off...
It's not really fair to compare an GT-R to a GTiR.
One is very much the flagship for Nissan and has much more solid performance across the range. The GTiR seemed to be coarser to me but still quite zippy but nothing like the torrent of power and acceleration that the GT-R is...
T.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
