Reflections on the bonnet is the easiest thing to do.... so easy i forget to do it sometimes :)
It's just a reverse layer of the eye's, erased a little, then lower the opacity to about 20-30%, and then Overlay it on to the original layer.
And of course with WRX's the bonnet scoop kinda makes it a little harder to get the reflection right.
https://www.sau.com.au/forums/topic/149791-carz/page/2/#findComment-2794605
  • Replies 56
Posted Images
Yep, thats pretty much it. I forgot about the Hue/Saturation tool...thats a great idea.
Thats the thing with photoshop, there's many ways of doing the same thing.:P
im too lazy to do it (or lack skills to :)) we'll leave it up to you to make them ;)
https://www.sau.com.au/forums/topic/149791-carz/page/2/#findComment-2794631
    • Thanks for that mate always a good help
    • It's not really a calibration issue, if the voltage is really at 2V. If the voltage is 2V, then that's what the TPS is putting out, and the Haltech is seeing that and 2V is about 40% open (you know, between 0.45v being closed and something close to 4.5V being fully open). So, that would suggest that the TPS is maladjusted, on crooked, something something something. Or a wire problem.
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
