Would not use one of these personally since there's no dampener built into it as there is in the OEM, NISMO & C's ones.
The dampener is built into the stick itself under ( part of ) the counterweight and helps to shift cleanly and as you can see, this shifter doesn't have a dampener built in.
I have owned and used a C's one which is about a 25% - 30% shift throw reduction and works great. To get the full benefit's your syncro's should be in top condition.
Also owned a NISMO one which is about a 10% - 15% shift throw reduction and works great but doesn't feel much different from the normal one.
Just my 2 cents.
  • 4 weeks later...
don't waste your money on them, they rattle and are really crap quality. The place that made mine even had the guts to imprint nismo on the side of the shifter.
Oh great! And they dont fit that easily too. My mechanic tried on Sunday and said that the shifter is the wrong size and all. The seller claims that it will fit and their solution was to sent me previous buyers email addresses and ask them how to do it! Not happy Jan!
:laugh:
got one for my car from ebay, paid $57+ postage total, didnt have any instructions with it, but once i sorted it all out and eventually got it in (was a bit tight) it felt a bit crap untill all the parts wore in which took a week, now it feels BEAUTIFUL, so happy with it, definately some of the best money ive spent on the car... had it for 6months now and no problems... looks exactly like the one in the first pic...
driving anything else feels like a tractor!
I have one of these in my 32gtst, looks exactly the same, they are counter weight balanced, and are a solid feel without the damper, feels better like that than the original. My throw seems to be 50 less.. which is great, wouldnt go back. Easy to fit, but the little white cup on the end of the shifter didnt fit into my slot in the box, so i had to change that from my original, does have a little rattle, but sound deadner under the gear boot has fixeed that. For the price, best way to go, reliable, easy to fit.
Just took ownership about ofa an R33 GTS-T a couple of weeks ago and the car was fitted with a (very rattly)C's copy shortshifter.
Over the weekend (the first time shifting a little agressively) the whole shifter came off. The plastic insert (that goes into the small ball at the end of the shifter and into the selector) had split. It's back in there for the meantime but I have to shift slowly.
My question is: is this part included in the eBay kit? Having never seen the standard shifter I'm not sure if this was a stock Nissan part?
Can this part be purchased seperately from Nissan?
Cheers for the help,
Aaron.
just blocked the noise getting into the cabin. you cant fix the rattle as it is the lever inside the box.... not the rings underneath as you may be thinking. But works an absolute treat!
Edited by aaron_25t
hey guys
ive been looking for a while to get a short shifter into my 33, and spent a lot of time contemplating which to buy: C's, Nismo or the cheap copies off ebay, until the other day i was on ebay and some how came across and oridinal Tomei short shift kit but was second hand. it didnt bother me though and it had a buy it now price of $140 so i bought it.
i put it in myself with the DIY instructions off an SAU member.
perfect fit, no noises, tight and reduced the throw by at least 35-40%.
i suggest listen to what most people have to say and buy the right parts for your beloved baby, invest in only the best
thats my two cents
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
