Well i was thinking the other day... and no it didnt hurt:D
Since we are such a close net bonded group of lads and lasses in WA that i might be a goot idea for everyone to post up what they do for a living.
Some may have issues with this?? but i thought, we might as well know what services we can offer each other.
Could be to our advantage some day.
Allow me to start:
My name is Nate.
I work as a software and electronics hardware engineer for a Automation company.
we do stuff like advanced control systems for residential and comercial projects. Stuff like the belltower (the lights), we control 90% of burswood the perth convention centre... Blah blah...
S
o if anyone has any electronic or electrical or software (no i dont do IT, but i build a mean computer though) problems or questions, i can help you out.
Take it away guys... and peace to possums
https://www.sau.com.au/forums/topic/15003-what-do-we-all-do/
  • Replies 170
I feel like im at one of thoes group session councelling sessions.. "hi my names um kylie and err.. i have c#*k suker a#s wipe f%@k face... terrets.. " lol.. just kidding!!! lol.
Truth? well im kylie and i work as a childcare assistant and go to uni doing my teachers aid diploma to bridge me into a teaching degree next year.
https://www.sau.com.au/forums/topic/15003-what-do-we-all-do/#findComment-304535
I am Bayley and am a part time Customer Service Officer. If ya wanna whinge cuz somethings broken or not fixed in time then call me and I will have a fight with the right department to get them to go do it for you now. Could be a stressful job but I am pretty laid back so these people yelling at me that the light bulb still hasn't been changed doesn't really phase me too much.
https://www.sau.com.au/forums/topic/15003-what-do-we-all-do/#findComment-304901
Shaun,
Office monkey for the family Financial Planning firm. Unfortunately i have to start at the bottom which is taking its time but at least i get to whore alot and try to keep most of you in line:D Mostly i just process applications and crunch numbers.:drooling:
https://www.sau.com.au/forums/topic/15003-what-do-we-all-do/#findComment-305398
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
