STILL HAVE THIS STUFF FOR SALE...
An RB25 non-turbo GTS engine - good condition, has done just over 90,000km's. Also the ECU and wiring loom. Includes things like the alternator, hoses, clutch etc etc... Selling for $1000 $800
A GTS-t gearbox, manual, for the turbo R33. The bloke that owned it before me put it in there because he was going to put a turbo engine in the car but didn't get around to it. It is in reasonable condition... Selling for $1000 - SOLD!
Will sell above items for a set at $2000...
Plus all the other little goodies that get moved around such as:
FROM THE NON-TURBO: Series 1
Fan shroud $40
Instrument cluster (non-turbo), reads around 90000kms $80 SOLD for $85 incl postage
Radiator Hoses $5 each
Starter motor $70
Air conditioning compressor SOLD $80
Clutch, Brake and Accelerator Pedals $90 set or can separate
Air box $30
Air Flow Meter $90 SOLD for $80
Electric fan (for air conditioning) $60
ECU and Wiring Loom SOLD for $170 incl postage
4 Stud Hubs, Calipers and rotors for all wheels $ Make an offer
Make an offer on 3 16"rims - only 3 as one is cactus
FROM THE TURBO: Series 2
Fuse boxes $20
Gearstick Sorround, Slightly damaged material, no ashtray $10 - SOLD
Front Control arms $50 each
Dash board $50 - has scratches and one damaged air vent - just needs a clean
Dash surround (goes around climate control unit/CD Player etc) $50 - SOLD
Air conditioning condenser $100 - SOLD
Heater unit (assuming thats what it is called - behind dash, big white thing) $80
Support brace (assuming its called that - metal brace behind dash that goes across width of car) $20
Climate control unit $100 - SOLD
Steering Column $100 - SOLD
Door hinges $5 each
Bonnet hinges $5 each
ABS Unit $80
Other kick panels etc $20 each
Air snorkel $20 - SOLD!
Heater hoses and stuff like that $5 each
Also, many other little bits you might find in a half-cut (centre console forward). If you are after anything I haven't listed or want a picture of anything let me know so I can take some photos and send them to your e-mail or something...
Pictures at:
For the engine:
http://s135.photobucket.com/albums/q128/Chessa87/Engine/
For other spares:
Edited by Chessa
For the guy who contacted me earlier last week, send me a PM and we can work something out with the engine etc. If need be I can take it to Sydney if you can get someone to pick it up from there.
On the dash of the GTS-t, there are some little vents (Up the top of the dash) that are used to aim at the side windows when on "Window" for fan etc.
Also the A-Pillar plastic bits.
How much each? (Mainly want the drivers side A-Pillar plastic)
Might be able to pick them up tomorrow.
I am located in Nowra, NSW. About an hour south of Wollongong.
Really would prefer not to pull apart the engine, will drop the pirce to $900 without loom and ECU
Edited by Chessa
you've already started pulling parts off it?
Whats left on the motor? Im interested in it, dont need an ECU, just motor and loom but price depends on whats left on it. Not willing to pay the asking price of 900 if its missing stuff.
cheers
Simon
  • 4 weeks later...
do you have an ecu loom for the series 2?
Hey
The one from the Series 2 turbo got pulled out and put into my car when I did the conversion. I sold the loom for the non-turbo also. Sorry I can't help you out.
  • 5 weeks later...
  • 1 month later...
UPDATE:
Had an accident so now only have 3 good rims, will take any reasonable offer to get even 2 off my hands. Comes with tyres.
All calipers, hubs and discs off my GTS are now up for sale - finally completed the brake conversion. Will separate. Make an offer!!
  • 3 months later...
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
