I ran a 14.52 tonight wooho
I am stoked cos i drove pretty crap take off wise 2,7 60ft time.
i got a turbo back exhaust but with a stock cat. (doh) air pod with a sort of partition and walla.
i am so hooked on the drags now, no more perviing at skanks time to pull these numbers down, i had 5 runs all good
thanks to Cam and Zanda for the support and Cams dad (the clutch master)
zanda congrats to you for the 14.3 you BAS*TARD
lol
lata everyone
P.S anyone wanna buy my wheels??
Wheels only $650 no tyres 17x7.5 & 17.8.5
https://www.sau.com.au/forums/topic/15011-yaaay-my-first-run-at-the-drags/
  • Replies 47
I went down for the first time ever too!!! My best time was 14.166 @ 101.12mph... Crappy 60' of 2.416secs and reaction time of 1.129secs... My main problem is suspension is setup for circuit racing, sssoooo much traction problems... :(
The drags finished tonight... Now they are on Sundays from the 11th of May...
EDIT: Whoops, my bad, my best time was 14.147 @ 100.67mph reaction time of 0.905, 60' of 2.427secs...
Alan.
Originally posted by MetBlue_GTST
I went down for the first time ever too!!!  My best time was 14.166 @ 101.12mph... Crappy 60' of 2.416secs and reaction time of 1.129secs...  My main problem is suspension is setup for circuit racing, sssoooo much traction problems...  :)
Alan.
you got enough for a 13.8 there mph wise. Just get the 60ft into a 2.1 and your there :mad:
Did you run lower tyre inflation (say 20psi)?
Do you have pineapples?
It's lots of fun anyway isn't it.
And the VN ran 15.74. Yep, that was the red one down there. Oh well, not to worry, it tried. Only paid $2000 for it so can't complain to much. Beats all the other VN's round here. She is naturally aspirated remember. One kid down there in his VR spent tonnes on it, shift kit, faster diff gears, extractors, etc, etc, and only managed a 15.58. Poor kid, what a waste of money.
no i didn'y go.
The car needs an injector or two cleaned. The ping comes in strong at 4700rpm and although it's making 230rwhp it's afr is high 9s there. The rich fueling and very little timing should eliminate ping but this means one or two pots are leaning out whilst the others are waay overfuelled. I'm pulling the plugs and possibly injectors out today to find out for sure.
my first night last night for runs too, great fun
didnt know u were all going :)
anyway ran a best of 14.56 @ 96.9mph
running street tyre pressure - 36psi in bald 255's :mad:
only engine mod:
catback exhaust, still got the stock airbox.. running stock boost
im keen now to lower that time, need more launch practise...
and mods ;)
I forgot to bring down my portable compressor and a guage so i could let down the tyres, so i just guessed and let them down a little bit, it did help a bit, but i DEFINITELY need to practice my launches!!!
BOOST is that your series II
do you want the grille or not man, you slack biatch
yeah there were a few lines down there, i didnt know anyone, i was clinging to cam and zanda all night, incase the other skyline owners were mean
ah well i will catch people at sundays one, yaay
Yeah strich9 i am gonna get an EBC shortly and a cam gear as well and then get the AFC back in and tuned in that should make a world of difference oh yeah and let the tyres down also.
and diff cradles. thats all i am doing for now,
but judging from the launches i did i know that 14.5 is shocking, oh yeah also should get that larger cat for the exhaust no sense restricting for no reason
Alan.
just for your information, reaction time doesnt count upon your final time.. The counter starts as soon as you pass zee laserzz.
but if you react in under 0.4secs you get a red light, but your time is still recorded.
*ZAAAAAAAAAAAAAAAAAAP*
Shaun
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
