Hey, i'm lookin at doin my timing belt soon and was thinkin bout doin the cam gears as well, but know s**t all bout them. Just wonderin is there any advantage to havin them on or not, and what the difference is between the intake and exhaust one, since most companys have different part numbers for them. I've found some on ebay but dunno wether to go ahead and buy em or not, manly coz of reasons above
https://www.sau.com.au/forums/topic/153064-adjustable-cam-gears/
Dude............do a search, heaps of help here.
The value of adjustable cam pulleys/gears and what you get out of them depends on your supporting mods.
I'd also say that you won't need one for the inlet side unless you have removed your variable valve timing.
My advice - don't bother unless you have/intend to get supporting mods. Buy a reputable brand, avoid eBay.
Go to group buys or search on 'Slide' on SAU, you won't get a better deal from either option.
Have a look in the group buy mate you can get one for $90 delivered. This is what I did when I got my belt changed, only gained 5kw but for $90 thats not to bad. You only need one for the exhaust side as the intake uses NVCS. Have a look at the link below for more info on NVCS.
cheers
http://nissanskyline.6te.net/NVCS.htm
What kinda mods are we talkin here?? I've still got the car pretty stock, however lookin at throwin money at her later in the year. :yes:
Since you got an r33, you will only need exhaust side of it..
Supporting mods?? hmm i dont know what the other guy was talking about..
hmm to make most use of it after installation of the cam gear and tuning the gear itself is an aftermarket ecu.
With all the other usual mods.. Full exhaust, fmic, pod ..
I have seen gains from 5-10kw.. cheap power!!
What I mean is if you just buy a cam gear and slap it on, you might see 5kw.
If you have say a power fc and you install a cam gear you might see 10kw.
If you have a fmic, a bigger turbo, a power fc, zorst etc etc then you might see 15kw.
A cam pulley moves the cam timing, then it all depends on how much better your motor can breath, how much air can be forced into it, to make use of the move in timing.
Re-read the post............
I got adjustable cam gear put on my r33 and my tuner told me that he didn't tune it because there is will no power difference. My current mods are full xhaust, cooler, pump, safc, pod with heat shield and hks evc. does that sound right?
Quote Hot4's tech handbook:
'Where the turbo engine will gain most from cam gears is by retarding the exhaust cam shaft. Normally manafactures like to advance the cam more than optimum for peak power because their highly restictive exhaust manifolds and systems can force hot gases back into the cylinder, promoting detonation.
Start retarding the exhaust cam a couple degrees at a time and watch the power climb, particularly if the engine has a larger exhaust housing on the turbo or an extremely low-restriction exhaust system.'
I found this quite interesting, and has lead me to buy one soon for when I get slide max oversize turbo tuned properly.
I have a tomei cam pulley, used it at 5 degrees and got good power, I've still got it on, but had to reset it to 0 degrees for my poncams.
On a ECR33 Gtst with poncams, you usually don't need an adjustable cam gear.
I use the pon cams on my GTR with adjustable cam pulleys. i have a fully modified head ported and polished, 0.5mm oversize valves the works, and with my gears set at 0 deg the car hits full boost at 4900 rpm, with tweaking of the gears and fiddling with the pfc, inj and ign timing the car would hit the full boost at 4600 rpm. so they are worth the hassle if you want to gain smth extra, these things are realy the bang for the buck,.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
