are you guys sure the r33 thermo fan doesnt switch on with aircon? i thought it did. not constantly, but as needed.
Yes you are right, even R32 but i think we'd like to have the fan turn on a bit earlier than what set (factory temp set at 94degree i believe) by Nissan just to be on the secure side.
  • 1 month later...
  • 4 weeks later...
Thanks for the how to Cubes, worked a trick. But I think its a little too late for my compressor, I think the summer period has over cooked it. Oh well I have a replacement one here.
What gas are you running? Our compressors are not designed to deal with the high pressures experienced with R134a gas.
Find an aircon specialist that is licensed to deal with R12a; a MUCH better option.
I've had both gases in mine and the R12a is much better. I can no longer hear the a/c compressor roar, I can no longer feel when it clicks in and out and the power it sucks out of the motor is hardly noticable UNLIKE R134a.
R12a is a more efficient and environ friendly aircon gas than R134a.
Don't confuse R12a with R12. They are two different gases.
yeh i converted it to R134a gas and ever since then have been having probs. 2 weeks after I had it done it built up too much pressure and stopped working. They had to release some gas and it worked again for a few months then the compressor went. I'll have to get the compressor replaced and then fill it with the r12a then.
haha ive converted mine to R134a.
The power drain is huge, wouldnt dare turn it on whilst idling at lights :whistling: When coming to a stop, i always put it into neutral and rev a bit so it doesnt stall it self :P
lol mine wasn't quite that bad but it made the car feel very very dull.
  • 7 months later...
i did this and it worked a treat,
also added another wire connecting it to the black side of the diode then ran the wire into my cabin with a switch that connects to ground, now i can turn it on via the switch or via the air con
Say ur radiator temp has rose a bit, just flip the switch and instantly the overheat fan will kick in and aid in cooling your radiator.
  • 3 weeks later...
has anyone tried this on an R33?
I'm about to replace my aircon fan, as mine is seized, and probably has been for some time. although the aircon is still quite good :blink:
now to work out how to get the fan out without removing the fmic :devil: . i tried, but it doesnt look possible, so i unplugged it for the time being.
Edited by Munkyb0y
  • 1 year later...
as hot weather has come around in victoria, this requires a bump up to the top :yes:
took my car to get an AC checkup and they told me to wire in the radiator fan startup.
One question, after turning off the AC is the rad fan still on? or does the wire+diode signal the rad fan to turn off?
  • 11 months later...
Yes, I would like to do this mod on my S2 R33 for this summer! Does anyone know if the fuse layout is the same as the R32's?
Also, does it actually make much difference to the air temps (inside the car) when you've just started the car and it's ultra hot outside, but you're sitting still? I'm finding that for the first few mins it never really cools down much inside if it's >35C outside and I'm not doing >40-50km/h. On the flip side, once I'm doing >40km/h would I really need this 2nd fan going whenever the A/C is on?
Oh, and what happens if the car reaches 91C but the A/C is off? Does the overheat fan stay off? Or, in other words, is the overheat fan now solely controlled by the A/C?
Edited by benro2
will be trying this mod its got 2 be 1 of the cheapest 1s out and it will give me a chance to check if my thermal fan works (i dont trust the 1 the panel beater fitted)
  • 4 weeks later...
likewise - when i had my regas done the mechanic also advised running the thermo fan would knock off approx 5degrees from my current internal vent temp which is @ 11degrees
this is a fantastic mod, i'll do this today :P
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
