ok here are some pics i will do some more tomorrow for you all but i hope these will do
What a day nice weather if you like HOT but let me say thankyou to the smoke and beer fairy,
The drivers where good the cars were good and would like to say
SMOKY GOT A 1.18.8
and DAVE got a 1.09 i think it was faster then that any way
here are the pics
will add more info later
(((ANDREW )))
GUYS I know that Australia day may be a hard time to get away but im sure that the next track event the people that did not show nor who have even been to watch a event should come to see. great people and most of all the cars we love SKYLINES !!!!!! :D:D
Also in one pic you can see a nasty crack in the rotor which was on a 300zx :(:O
And also fire damage on the blue WRX
The silver BMW is lossing the Bonnet ummmmmmmmm :P:(:(
  • Replies 70
hey guys!
was an awesome day, as i was noob i am now addicted to track! thanks to all the people who came down to watch.
on the way home i threw the AC belt as the compressor bearing seized,
jess heard the bad noise coming from engine earlier in the day and thats what it turned out to be!
It was a great day, hopefully next time I'll have my line back & more SAU members will join in all the fun. :(
Got a bit sunburnt but the alcomohol eased the pain. :O
Good to see Andrew & Jees again, by the way great pics. :pwned:
Wow sounds like a great club day out.
Wish i was there.I hate not having a gf to drive me everywhere so i can get pissd.We would both have so much fun...
Had to do the brake pad change over to the streeters today.
Ive also got a few pics in my sig of the day out at wakefield i had last wed.Check them out...
Had a great day guys... nice to finally meet some SAU'ers other than the CC & Hornsby crew...
Will be on the track next time for sure!
P.S for those that were there.. I definitely look like a bandicoot or zorro now with my sunglasses mark!
Got to say it was worth the trek down to watch & T04GTR was quite impressive around the track.
Nice meeting some SAU NSW members - funny buggers some of yous are :P also, Jess & Andrew great seeing ya again, sorry wasn't able to stay longer.
Edited by pkblade
I'm really loving the body + wheel colour combo on that ceffy, looks tops
Thanks dude!! :)
Ando I cant believe what is said on that paper :(:):):(
HA HA HA HA...... nice work but i swear that piece of paper had something else written on the top......................... :):)
A great day indeed boys and girls, Well done to the guys who got out and had a run on the track - Smokey in particular giving it a red hot go and losing it a few times but still had fun anyway. :) Corinne drove superbly both under instruction from Boz and solo (still need to hold 2nd gear longer after entering the fishhook though :)) and the GT-R fraternity put on a great show. :)
I'll post up a few of my Skyline shots from the day shortly - sorting through 500+ photos isn't a small job.
All in all thanks to everyone from SAU that attended and we hope to see you again at the next Autosports event in the very near future. :(
Ian
Autosports & Xmetal Photography
Edited by Xmetal
Great day guys! loved it.. hoping to get some more sleep next time but we all know its not going to happen..
Thanks to the autosports guys for a great day!
Haha thanks Ian! still working on it :happy:
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
