Hi guys,
My old man has had one of those "mystry" dents appear - back 1/4 panel near boot - so some tool has lent up on the car or something or something heavy -who knows but it stands out like dogs balls!!
So which company doyou guys used or have heard are good? mobile guys around north shore anyone?
Cheers!
https://www.sau.com.au/forums/topic/153557-paintless-dent-removal/
Hi guys,
Cheers!
Hai Chris, I recommend son of rajab Of The Dings Ph# 0409 716 338. Has a shop at Brookvale but I believe he's mobile aswell. :)
PS sorry to hear about your dads car have had a similar experience. :P
Edited by JETR32
this wont fix your dent but it may make you feel better. I went to a movie and parked my car (the GTST) in the carpark on the end of a row. when I came back I found some f**knuckle had t-boned it! how's that for a mystrey dent! luckily it just damaged the door only. but it was pretty f**ked. rather than repair it I bought a new door. :P no witnesses, no cameras. not worth claiming on insruance (loose no-claim).
There's a bloke in Artarmon who does it. Forget the name. Can dig up his business card if you like. But I have used him before and he does a good job. Its opposite that Jack Hillerman's place in that little laneway if that's any use to you
Yeah she did about 4 years ago now.. its still dinted.. if you look carefully on the drivers door you can see it =(
Its like a permanent reminder of how she f**ked me over and emptied my bank account but never even paid me back to fix my car... i should fix it myself im sick of seeing it!
i wonder how much the dint men charge.... should get a quote myself
Your ex kicked the door in?
I didn't even notice it on your car. is it bad?
I'd be absolutely furious if my ex did that to my car. If someone has a problem with me, feel free to talk about it, but once the car gets damaged, that's it! :glare:
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
