Hi guys,
My old man has had one of those "mystry" dents appear - back 1/4 panel near boot - so some tool has lent up on the car or something or something heavy -who knows but it stands out like dogs balls!!
So which company doyou guys used or have heard are good? mobile guys around north shore anyone?
Cheers!
https://www.sau.com.au/forums/topic/153557-paintless-dent-removal/
Hi guys,
Cheers!
Hai Chris, I recommend son of rajab Of The Dings Ph# 0409 716 338. Has a shop at Brookvale but I believe he's mobile aswell. :)
PS sorry to hear about your dads car have had a similar experience. :P
Edited by JETR32
this wont fix your dent but it may make you feel better. I went to a movie and parked my car (the GTST) in the carpark on the end of a row. when I came back I found some f**knuckle had t-boned it! how's that for a mystrey dent! luckily it just damaged the door only. but it was pretty f**ked. rather than repair it I bought a new door. :P no witnesses, no cameras. not worth claiming on insruance (loose no-claim).
There's a bloke in Artarmon who does it. Forget the name. Can dig up his business card if you like. But I have used him before and he does a good job. Its opposite that Jack Hillerman's place in that little laneway if that's any use to you
Yeah she did about 4 years ago now.. its still dinted.. if you look carefully on the drivers door you can see it =(
Its like a permanent reminder of how she f**ked me over and emptied my bank account but never even paid me back to fix my car... i should fix it myself im sick of seeing it!
i wonder how much the dint men charge.... should get a quote myself
Your ex kicked the door in?
I didn't even notice it on your car. is it bad?
I'd be absolutely furious if my ex did that to my car. If someone has a problem with me, feel free to talk about it, but once the car gets damaged, that's it! :glare:
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
    • Hi, I need same this wing nismo , Does anyone have one for sale?  if any one have can contact me  00966546888343
    • Nah, lots of insurance repairs on V36 and V37 for pedestrians deployments. Reasons ranging from possums, to extremely severe potholes have deployed them. However, paying for the full repair can still be upto $5k AU some people have noted!
    • Hi, i got 1998 r34 4 door auto abs model and its manual converted with bigbox when i bought it . I successfully find the neutral and reverse light wire but can’t find the speed signal wires for speedo drive. I know its grey plug but on my loom no grey plug with 2 wires . I opened the loom upto where it getting branch with other wire, i’m amazed they is no wire. So need help how to fix the speedometer problem. I search on google it says some r34 model measure speed from diff sensor. Is it right? I talk to a wrecker he say no this isn’t right, i’m kinda stuck. Please help
