  • Replies 85
Finally got my right and left rotors for the rear on Monday and as luck would have it I had an early day care of the wet conditions so I got to fit them today. So now I have the dba 4000 series slotted rotors front and rear. Very cool. I have put the bendix ultimates front and rear as I said before I was running out of money so they were a cheaper option. No performance complaints yet, but then I have been bedding them in so no real chance to test them out. But I will say they are the dustiest pad by far that I have ever used. Not happy about that.
Guest Boxhead
im not sure how far that is from you, but on wednesday me and a mate went to noosa, we filled the tank up at yatala, and got there, drove around a little, and back to my house at tweed heads without needing more fuel... about 550kms i think... thats before fuel light came on
hey all just thought i make a start, i dont think ill ever be finished with my car. I got my r33 gts NA last august and it came bog stock with a HKS Super Drager Exaust and slightly lowered. The next thing to do wwas put the stereo in out of my old car. I then purchased some 17 inch chromies about a month later. Soon after that in went the subs with a basic but still custom install. As i save a bit more money i got both doors and all quarter panels resprayed. Then we were renovating the house and the front gate fell on it putting a hole in the front left quarter panel and bonnet. So back to the panel beaters it went. I soon installed some neons and other interior stuff like EL guages momo wheel and knob.
A little closer to the end of last year mum backed into it so back to the panel beaters again for a front bumper respray and GTR style front grille. I then got my licence in January, only to re end someone 3 days later as some **** WIT cut her off but oh well, if u run up someones arse its ur falt end of story :). I then got a boot lip style spoiler. In the last month i have completely re made my boot, which is now no longer a boot. I got it back today from the body shop with a brand new kit and some extractors and an Apexi S-AFC ii is going on in the next 2 weeks. I now have to save very hard to do a 5 stud hub conversion and put some 18's or 19's on it as the kit makes my 17's look like golf buggy wheels.
  • 8 months later...
Thought I might revive this thread, used to be quite good.
Since I last posted here the only addition to the GTST has been an oil-catch can.
I have just added to the garage a R33 V-spec GTR
Mods to date:-
HKS type 1 turbo timer
Tint
Nismo fuel/oil/radiator cap
BBS rims 18"x9.5"
Yokohama 265/35 R18 ES100 x4
Nismo Clear indicators
Alarm/immobiliser
Nismo GT gear knob
Otherwise stock for the moment.
OK well I have spent a truck load since I bought my GTR last October & all those that know me will vouch that I've driven it about a dozen times since.... Here's a list of mods/repairs:
Motec M800 ECU
Motec Boost Controller
2 reconditioned High Flowed R33 GTR Turbo's (blew them both)
Replaced all the oil feed lines & tubes
Installed new oil filter housing gasket (none there!!!!) & inlet manifold gaskets
Replaced all plugs/leads
Reground cams
Replaced timing belt
New tyres
Adapters (spacers)
Clarion Headunit & Pioneer Speakers
New exhaust, one with a cat converter....
and on & on she goes......
Anyways one step closer
Cam :D
meh.. i'm just getting to the point where unless i have a stupidly fast car that has 300rwkw+ i cbf modifying anymore as it costs too much :D what i want to do would cost $10k - I don't have $10k so i sit on my hands.
Hmm! Been running on default PFC tune for ages and now on default Data-Logic tune....a little better but not much.
thinks.....MUST get this thing tuned up!!!
Changed a few things lately. Got a 400R kit but didn't like it . Now in the process of getting a full on Carbon Fibre kit from Custom Carbon will be Bonnet, bootlid, front and rear bars and maybe sideskirts.
Power FC with Data-Logic has replaced the EMS DuelSport
Full Apexi Supersuction Pod kit
Bigger FMIC
Front throttlebody Plenum
E-Boost has replaced Audi DIY
HKS 2540 Turbo
Moved Washer reservoir to boot
Oil cooler with Thermostat and remote filter in the mail
other mods remaining are
Full adjustable Whiteline/DMS coilovers
Whiteline adjustable suspension bits and pieces
Pineapples....set for drag
3" Turbo back exhaust twin 3" tips
Nismo twinplate clutch/6Kg flywheel
HKS adjust. camwheel...exhaust
C's short shifter
Recaro Seat
Full harness seatbelt
Apexi RSM/G meter
Apexi Boost gauge
Nismo GTR Dash panel
Weds 18x8&9 and Mod 11 17x81/2&91/2 wheels
Lastly...but not leastly...Blue neons in boot and glovebox :D.....ok..ok..so i'm a rice boy at heart. :wavey:
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
