  • Replies 701
Posted Images
oo0o0o0o0o nearly half way through the day... i'll bet y'all have already blasted your previous times :) Can' wait for when car is fixed and I get to have my first turn at wakie... If only there were more hours in the day... We just didn't have enough time to drive 12 hours to get there, do track day for 8 hours then drive 12 hours home. We would've died along the way for sure :thumbsup:
And now some words of wisdom courtesy of my inner bogan...
GO HARD OR GO HOME
ARC IT OR PARK IT
GET 'EM SPINNIN' & WE'LL BE GRINNIN'
:thumbsup:
fantastic day. with my stockie i managed to clock 1.21.2 with which am pretty satisfied though being my first time looking back I felt I could have improved in a few corners. all said and done cheers to all the guys who organised it and looking forward :P to more such days.
hahah the volvo was funny on the track :P
But I think SAU is dead atm maybe only admins can post ;)
Anyway....great turn out today, it was brilliant to see so many new faces on the track and I hope they all enjoyed it.
The wet track in the morning came close to setting a record for number of spinning cars - but overall I think eveyone came through pretty unscathed.
Thanks Adam and Corrine in particular for organising, and Kel and Steve for standing in the freezing cold at the flags all day.
The forum was down last night.
Sweet day, was good to get the R34 out for its last run. But hope it wont be its last time on the track.
Paul, you're welcome to pilot mine anytime I'm at Wakie. Thanks for all the help yesterday. It's amazing what driving right does for your times. Thanks to all the other experienced drivers who took a lot of tme to help me and everyone else to learn to drive better
Guys - Lots of great effort by everyone who helped yesterday, but I think we owe Adam a major thanks. Back to back weekend events and both ran superbly.
Via El Presidente!
yep.... thanks to everyone that helped make this happen... and a special one to adam.
i had a great day.... thanks to everyone who helped me and gave me advice whether it was in or out of the car... appreciate it i learnt alot.
was quite good weather... a little chilly but its that time of year. it was good to experience some slightly wet conditions aswell. by the looks of it... everyone was going heaps good.
oh yeah tim..... i think i may have been converted from drift to circuit... well partially....still gotta have some power oversteer on corner exit.
Was about to say the same thing duncan, Steve you were locking that inside wheel @ the same corner every lap :P
Thanks to everyone who organised, but also huge thanks to everyone that took passenger's out (including me) on some laps, I think this is what makes SAU + Wakefield such a good day as everyone is happy to have people along and it encourages people to get out there..
Got a small sampling of photos..
http://www.crankroom.org/photos/sau_trackday/
Warning - some large ones when you click on them, but i'm happy with how they turned out..
thanks to all who made this day happen....thanks to all who pushed my car back to the pits...lol....and to Paul who got my intercooler pipe back on...had a great day as a newbie and it wont be my last....thanks Duncan for the driving tips which helped me keep in on the track all day...Anthony
I would like to thank all that came and also allowed me to safly slide and slide and slide all over the road IN CONTROL THOUGH :P
Paul your words help really well and after some modifications I think those track times will drop even more.
Adam thanks AGAIN for a great day.
Stevo for making me laugh ( THAT HELMET ) please someone post a pic of him in that black helmet.
And last two
Brad from cracking my back on every corner wicked car and cant wait when it has its over haul.
And finally Shell now since we have seen you twice three times now thats it i dont want to see you for another 12 months.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
