  • Replies 228
eyy bro when did ya do your engine??
your wheels were just looking and goin sick eyy?
what you do excatly to it?
join the club my donks fuct 2 :dry:
he doesnt know :O he thinks it was too much bee-r but i think it had something to do with the fact he was playing around with the injector setup on the pfc h/c ahaha
#5 has a nice compression of like 60 hehe :(
despite what people think, ignition cut rev limiters like bee-r ones are quite harsh on engines. as you can imagine a huge flame going through the head/manifold and turbo doesnt exatly help things. when i had one on my sr20, i broke 3 rocker arms simply because of the strain it places on the head. Since i have gotten rid of it the engine has never been better
this is true, however the Bee*r limiter only cuts sparks at red line, unless you hold the red line for extended time, the damage will be minimal and gradual.
What Exactly is a Beer Limiter?? can someon Pls explain thanks
-JuLiuZ
what i gather from what ive seen and read, its a devise that cuts spark at a preset rev limit or at the rev limiter, so when you hit that point it doesn't spark, but dumps mass fuel/air into the exhaust and then (i think) sparks as it is exiting(?)
this is why it pops and farts and shoots flames out the zorst and thats why it puts strain on teh engine as exploding fuel/air expands very rapidly, stressing and fatiguing metal
So it's Sorta Like Anti-Lag wif the Back Popping Action eh???? hehe :)
-JuLiuZ
So it's Sorta Like Anti-Lag wif the Back Popping Action eh???? hehe :D
-JuLiuZ
not really, antilag retard timing and works throughout the rev range and does not cuts sparks, allow some fuel to escape....hence more damaging
where Bee*r cuts spark at red line, so cold fuel will exit and detonate at the manifold instead.
I dun get tho, I thought fuel will detonate at certain pressure anyways, the sparks are just there to give a more regular timing
it would but normal combustion engines dont create enough pressue, but thats how diesel engines work, no spark plugs in them
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
