The R32 RB25DE VRS kit is around $275.
It includes all top end gaskets consisting of inlet manifold gasket, plenum gasket, exhaust manifold gasket, rocker cover gaskets and valve stem seals. There may be more thats the most important one off the top of my head. :cheers:
If I was to buy JUST the valve stem seals from Nissan they wanted $330.. lol
i have a question for you guys i have an rb30 block and a rb26 head i want to put them together is it possible if it is how do i go about doing it and where do i source the parts to do it thanks alot.
dude... you've got 99 pages here which pretty much give you the ins and outs of exactly how to do it. There is also a guide floating around (i think Cubes did it). Infact there is a link in his post above this!
Andrew
I thought I'd update ppls..
Loading up say 4th gear at 1500rpm starts to see boost quickly then it goes flat and the turbo sounds strange, if I hold my foot in to it the turbo starts to make a really strange noise (almost a popping noise) then the car begins to jerk around. nasty pasty. :)
I have never actually held my foot in to it when it has that flat feeling so I haven't heard the popping or felt the jerking before. Never again will I do it. Sounds really bad.
Not to worry, its never really in that zone anyhow. :cheers:
A good excuse to pull the little terd off. :D
Welcome to the world of compressor surge:cheers:
Andrew
thanks alot for your help, wha tkind of power have you seen this conversion produce, i am living in the united states and there is not alot of people that do these kind of conversions so i jus wanted to try something new, again thanks alot for your help guys.
What, you guys had enough of buying every sr20 on the market and driving the price up for the rest of us? Want to move onto something else to overvalue do ya?
(not that i won't sell you a rb30 short motor...)
guys...
if i through a rod in my 25det could i just bolt on a rb30 bottom end?
would like to keep compression same maybe a bit lower...
im running 18psi through standard motor and i know it will fly apart soon, hahahaha
any help would be great
thanx
This would have to be one of the longest threads I've ever seen and by far the most useful.
Cubes and Sydneykid have been saying for quite some time that cams should become before upgrading the plenom, in particular TOMEI 256 cams. I have a Rb25 head with VVT that is ported and polished (mirror finish).
Has anyone used these cams in a 25/30 and has dyno results to show?, I'm interested at looking at the mid range Hp and Torque.
i am sorry if this has been asked but can you use SR20 pistons when building up a rb30det?
and does anyone know a good place to get rb30e pistons from.
thanks
I've read about using sr20 pistons in them before, Blue r33 with 26 head 30 bottom that was in nzpc a while ago was using them. I'm still not sure why anyone would do this in preference to using forged 30 ones, needing to buy two sets of sr pistons bumps the cost up a bit.
A bit of the topic, ive got a rb30det in my R32. Has a stock bottom end with a R32 RB25DE head. Ive got an old school t04 on it with a smaller exhaust housing. Its running out of puff around 300rwhp.
Just wanting to know what turbos u guys are running and the power your making, and how the driveability is with them? Im after something that will produce 450rwhp with a good power band?
    • I do believe from context he is talking about a S0/S1 R33 RB25 with associated ECU and Wiring for that, and a manual gearbox into a R34 N/A Auto. I don't have the knowledge of all the pinouts and such but my gut feeling from doing my own conversion is to use as much of the R33 stuff that you can. The "car" wiring is quite seperate from the "Engine" wiring when all things are considered. The only things to truly consider 99% of the time is the cluster, reverse lights and potentially disabling the 'not in P/N' immobilizer circuit.
    • A realistic expectattion of how long it has to last also comes down to.... when do you think you will be banned from registering and driving old petrol powered shitters? It's 27 years since that thing was built. It probably rusted out 15 years ago. It was probably repaired and looked OK for another 10. If you do a similarish bodge job now, or perhaps slightly better with some actual rust conversion and glassing, then.... get another 10-15 years out of it, after which you'll only be permitted by the CCP to drive electric cars manufactured in their Shenzen zone anyway.
    • Let me assume that the concern over a manual ECU is that the NeoDET that you have was an auto and has an auto ECU. That ECU will not be a problem, but you WILL have to Nistune it. And you would have to Nistune it even if you had a manual ECU, because the turbo ECUs will shit the bed if they do not have all the things that they were told they have to have, to be happy. The big one being the TCS CU, which you won't have in your car. Anyway, with an auto ECU (which I have running my originally auto NeoDET in an R32) Nistune allows you to put in a Stagea image which doesn't panic about the absent TCS, and allows you to override a whle bunch of other annoyances that would otherwise see the check engine light on 100% of the time. Also, you can't wind up the power very far on the stock NeoDET ECUs without Nistune, because the boost sensor gets in the way. Nistune allows you to push that problem much further up the dial. Do you even have the boost sensor with the engine? Without it, you are SOL and will need an aftermarket ECU (or to find a sensor somewhere, god knows where). I can't tell you what the wiring loom differences are in a 34. But what Duncan said above needs to be considered. When you say "loom", does that include the transmission loom? Because you will need to swap out the auto tranny loom for the equivalent manual loom, and get rid of the neutral/park start interlock (basically hot wire it).
    • I have had the r3c in for years now, maybe close to 7 years and it has never missed a beat, anyone can drive it. Super easy to drive around town, the hotter it gets does get a little hard but it holds the power easy as
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
