The GTR/GTS4's run a block/sump adaptot plate so it also lowers the sump down slightly.
Anotonys GTS4, everything is VERY close. The bonnet had to be cut as the cam belt cover was touching.
my adapter plate is only about 8mm thick, hopefully there was more clearance than that with the RB26. just had a look in the engine bay, the steering rack looks higher than the crossmember.
Edited by Scooby
shanef i have seen spacer plates put in between the crossmember and the chassie rail befor to get the motor down lower
thats one thing to consider if i dont sort this problem out...
Shane, I have cut about 100mm piece out of the one of the under bonnt supports where it hits the cam belt cover, now my bonnet shuts and just clears.
What turbos you using there?
the turbo's u see there in the photo's are the R34 N1's, i just put them on with the dumps attached to see what type of clearance i had/didnt have between the firewall, which it seems like i dont need to mod them! (still gotta double check) but im swapping these turbo's for a set of Trust T618z
Hi Shane, not sure what's going on there. Cross member clearance shouldn't be a problem, the deck height is increased at the upper end of the block from the top of the water pump upwards. And the bonnet should well and truly close if you can fit a strut brace under there, the're a lot higher than 38mm above the cam covers. The engine is supposed to be on a bit of an angle but the clearance should still be good. Try looking on the GTROC UK site for comparison pics
http://www.gtr.co.uk/forum/upload/52458-rb...ight=r32+combat
at the risk of stating the obvious it seems that the whole engine is tilted way to far up at the front and that's what is causing the sump to hit at the rear.
thanks mate, i frequent those forums alot, they're a great bunch hey :ninja:
the things that got me is that the rb26 engine mounts are sitting flat on the engine mounts on the rails! but the fronts tilted like a mofo!
adapter plate is only 10mm, so pretty much fark all (surely thered be better clearance from factory than 10mm)
i'll go outside and grab some photo's.
im fairly certian they are, as i farked around for a good hour or so trying different combo's between the gtr and rb30 mounts to fit it properly, but i'll certainly double check that when i pull it out.
qik visit back to my brain straining issue.
Pulled the wastegate off, checked that it is sealing, checked that it is working with compressed air, all is fine. No diaphram leaks and no leaks on the intake side.
Still it will not boost past 0.7 bar. Ive put a 20 psi spring in, tried disconnecting the gate altogether, boost pressure to the bottom of the gate, to the top of the gate to both top and bottom.
Makes no sense at all ????
Help
annoying part is - that it was running consistent 16 psi previous to me removing the spring the first time
makes me not want to remove my 1.2Bar spring from my new Wastegate
definately a puzzling thing
Nothing else changed at the same time? this is a really troubling problem. How is the fuel pump pressure now? It's about the only other thing I can think of right now.
Engine with the machinist this morning. Aust post suck for being so slow but all goodies now in place for extreme funness!!!!
they wouldnt be 2860-10's would they geoff :)
i'm voting that there's some funnyness with the mounts.
yeah more than likely, will find out on the weekend i spose.
cheers for the ideas though guys :happy:
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
