Dyno results for today were 480rwhp on 18psi - Im pretty happy with that :-)
Started to lean out a smidge anything over that so looks like Ill need two 044's now.
Full boost with the T04Z is 3600rpm on the dyno.
Its pretty angry now.
Hi Brad, I have seen 650 bhp using a single 044 and that with some fuel returning to the tank. I did measure that return and it was enough for another 80 bhp or so. So I doubt that the 044 is the problem at 480 rwhp, maybe have a look at the lines and fuel filters first. Also make sure that the pump is receiving the minimum ~13.8 volts.
Brad in Perth had a similar leaning out problem and his problem was the lift pump running out of flow.
:D cheers :P
Yeah it could be the lines - good point. My 044 is in the tank.
It runs straight of the battery via a relay so voltage isnt an issue.
If you have a pressure gauge, compare the pressure at the fuel rail compared to the pressure at the pump. They should be the same, if the pressure at the pump outlet is higher, then there is a restriction in the flow.
:D cheers :P
no to use rb26 head studs on a 25 head u need to drill the block/head to suit
rb20/25/30 are all the same type 12mm and 26 are 13mm from memory
you just need to source 25 ones :wave:
just bought some arp head studs and on the box it says 11mm for teh 25 and apparently teh bloke rekons teh 30 ones are also 11mm but were 30 odd bux more expensive
would you also need an after market main stud kit if running around max of 24 psi with about 300rwkw??
Edited by humz
The rb30 ones are heaps longer, main stud kit not needed, but while its apart, its easy to do, roguepi on ebay has them fairly cheap.
Nice result Brad, what size turbine housing you got??
And what size injectors?
ahh yep 11mm for 25 and 12mm for 26 head studs
i purchased arp main studs, werent to expensive either :rofl: shame they dont make them in the 2000 series for the 30's tho
i got all mine from [200] on the forum, very nice bloke to deal with :D
It lives. All together and running in for dyno tomorrow but the bugger doesn't like the old fuel or the 26 temp sensor which is a direct plugin but reads mega high.
Oh well some fun for tomorrow.
Hey Andrew
850cc Sards
and 0.84 exhaust - split pulse
Injectors should be big enough hey, you run a rising rate regulator?
Also what size exhaust and how long (full/ half) you got?
Post up or PM me a dyno graph, im keen to see how the power is compared to my GT35/40.
Edited by sky30
WELL DONE Brad !!!!! That is some serious hp for only 18psi....now its time for 30psi+ and making boost at only 36rpm..some people dont see that with a 35/40.
Goes to show all your bits are doing the goods...well done again.
Ariel
brad if its a 32 then its the fuel lines. we had the same problem
over here. the 32 lines are smaller than the 33/34 ones.. i ran 512bhp @ the hubs on one tomei in tank pump, but mines a 33, my mate ran the same set up in a 32gtr and ran out of fuel @ 495bhp @ the hubs.about 570 @ the fly..bernie.
Brads is a 33. I thought all skylines has 5/16" fuel lines yeh?
If it was a 32 he would be lucky enough to utilise his hicas lines as fuel lines as i think they are about 3/8"...farking imperial is shit house, 8mm is bigger then 5/16" and 10mm is bigger then 3/8". Being Jap i thought they would have actual 8mm fuel lines not 5/16", or maybe they do?
I just got to scan dyno graph - will post it up here soon.
Sard regulator, 3 inch exhaust full length - with a CES cat ( rated at 700 bhp )
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
