we got sks package and then i pinched the tops off the teins and used them since they were spherical bearing, not rubber.
Before we changed to SK's deal, we put softer springs on the teins, and i must admit that helped a little bit but it was still stiff...which led me to believe that the shocks were still crap in terms of their valving, from them to the SK's was a massive improvement all round. Had to play with spring rates abit, but nothing too major. However the aussie spec ones seem to be loads better over the jap ones.
We are way off topic here, talking suspension in rb30 country.
Edited by r33_racer
A question for the guys that have been driving around with the RB30 hybrid motors....
Have you had any problems with the bottom end strength ??
I have been told by 2 experienced RB26 mechanics (one worked in Japan for Nissan) that the RB30 bottom end wont handle high boost and is the weak link. I'm not sure if this is just because they are RB26 biased or if its in fact true...
It wont stop my build, i'm just curious.
lol; no. Which has reminded me; its time to update it. :)
The blokes are Boostworx are top blokes; always done the right thing by me from the start so its well deserved.
There's so so many workshops out there that simply do not give a sh*t.
ok guys i need help im only a newbie....
i am currently rebuilding the rb30/25 to put into a lh torana 4 door.
i have read the first 86 pages in the last 2 days and i just need to ask one thing...
i am going to buy a rb25de engine for the head and bolt on acc, though can i use the non turbo loom in a turbo application with a power fc?? or should i lok at buying a rb25det wiring/loom for ease and better use.......
HELP!!
I am 90% sure you will need a turbo loom due to the knock sensors.
you may be better off looking for a power FC first and buying the correct loom for it.
it really depends on wich RB25DE head you are using 33 or 32.
if it was me I would buy a R32 re25de and use an R32 rb20det loom with an ap engineering pfc.
the loom and ECU will dictate wich CAS, ignighter and injectors you can run, once again in my opinion the r32 loom will be better as you can run top feed injectors.
Those of you with GTR's and or using GTR looms.
The knock sensors.
GTR
GTST
The GTR knock sensors don't screw in to the RB30 block as the thread dia of the GTR's bolt is too small.
What have you done/easiest way to sort the issue?
Brass piece chopped off and then drill/tap that brass piece to suit the GTR knock sensor bolt?
Or isn't there enough meat/difference in thread size to do such a thing?
i was goin to use a r33 rb25de engine for the conversion, tho im waying up weither to just buy a rb26dett head??
the only thing is price...
i was going to use the rb25de head with rb25det springs and maintain the vvt...
even though i get the de loom with the engine i will probably just hunt down a rb25det r33 loom or can i use the r32 rb20det loom???
cubes, i havent got to the knock sensores yet though what do u think would be the best approach as u have done it all....
thanks guys!!!
The knock sensors.
GTR
GTST
the bosses are there - on mine anyway - you just have to drill and tap them. the GTROC thread where R32 Combat / Andy shows his rebuild has good pics.
The knock sensors.
GTR
GTST
im not running them, simple lol (autronic SM4)
cheers champ.
Just a question before i buy it, am i able to use a rb25de NEO head??
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
