Where have you people who are using R33 heads been plumbing you oil return pipe from the front right hand side of the head? do you get a "T" peice and blumb it into the turbo drain into the sump?
cheers :P
After a lot of hard work and long nights my RB30det is now in the car.
I have spent a few hours tonight trying to get it started and have not got there yet. this is frustrating
Fuel pump working - check.
CAS working - when i remove it and rotate it with the ignition on the injectors click and the fuel pump turns on
everything is wired up bar 1 plug on the AAC valve. the r32 loom has no provision for it.
I am still working out the best way to test spark. any ideas?
I have had to use R33 turbo injectors and it involved cutting up the original loom and grafting in the plugs but I have done it before for GTR injectors and no problems.
the motor turns over fine just does not start
when the crank is set to o deg btdc the cams line up with the locator pin marks perfectly.
so its fuel or spark i am missing or some electrical gremlin somewhere. if anyone has any ideal please shoot them my way. my goal was to have it running by tomorrow night.
so so tired...
so so tired...
What ecu are you running? If aftermarket, what was it previously tuned for?
I am using the following bits
RB30E bottom end :P
RB25DE VCT head from an R33 - removed VCT solenoid and used the hole to feed oil to the head -
stock plenum R33
R33 injectors
R33 AAC valve
R33 tps, (all sensors on the head are R33
R32 CAS
R32 ECU remapped to suit the 370cc injectors
Will try the timing light tonight. hmmmm
wake up at 6am go to work finish work at 4pm. go home work on car till 1am. sleep for 5 hours - repeat for 3 weeks...
damn i am tired...
car should start with no afm, it'll just run like a pig and stall etc etc lol
it could be that ur battery isnt supplying enough juice
have u checked to make sure theres fuel getting to the rail?
thanks dudes :P
pulled the timing cover off and made sure the cas key is correctly set to the cam key.
the afm is plugged in and there is fuel getting to the rail. I am starting to think it is of 2 things.
1. there is no spark. because i have tried advancing and retarding the cas and no difference. and i can hear the injectors pulsing.
2. I have buggered up the injector firing order while making the new injector loom. this wil be a bastard to diagnose and will mean pulling off the plenum again.
I will make sure i am getting spark tonight.
also battery would be going flat but seems to turn over the motor fine. I am sure it is something silly. it will get there.
Also how long should you have to turn over the motor with ignition disconnected to get oil pressure?
who knows...pull off your oil feed line to the turbo and let it spit into a bucket for a while and then hook it back up. Once it spits abit out of the line there should be oil pretty well everywhere else. It doesnt take long for it to work its way through the motor.
may sound silly but a similair thing happened to me on my first start up that cubes will remember, haha!
It just turned out that my fuel lines were the wrong way round where they connect near the plenum!
HAHAH ive done that before :thumbsup:
Dash lights are all on when cranking?
you can also try the carbie cleaner trick in the TB then crank, if it coughs like it wants to start, then you have no fuel and do have spark.
Well she is in and running :thumbsup:
rough as guts but running...
mr rbman you my friend are owed beers :(
just before you posted this this afternoon I looked at an RB photo and realized exactly what i had done. I then had to sit at work and look interested for the next 3 hours...
race home swap them over and ALIVE! it will not hold an idle and misses loke no tomorrow but it is running. tuning and testing will commence in a few days :) I have had enough for now
haha, thought your problem sounded far too familiar!
Well she is in and running :)
race home swap them over and ALIVE! it will not hold an idle and misses loke no tomorrow but it is running. tuning and testing will commence in a few days :D I have had enough for now
I have a question re CP Pistons.
I know they are off the shelf ones available for the 26/30 combo...
Is there anyway that these can be customised to tolerate high horsepower / boost applications? I am going to more than likely get a set with a 22mm pin diameter. I've read that the rings can be moved down on the piston for high boost. Can someone give me some info about getting a set custom made?
Also, dry sumps. Has anyone bought a dry sump for the RB30 motor? If so, where did you get it from and how much was it?
CP will make one off custom sets to order - the price is considerably more.
You must be planning to make an immense amount of power as there are a lot of off the shelf CP's out there making spastic power.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
