A question to those who have done the conversion with an RB25 head + Greddy Plenum with throttle body adaptor.
What have you used for the throttle cable? The factory one is too short even with the brackt supplied with the kit.
Edited by MintR33
Ok, guy just reviewing, the one idea i read about, shaving the head to lower the compression with the combination if a rb30et bottom end and a rb25det head, causing a low compression around 7:1
anyone have any take on this? im prepared to do it, id love to know of anyone who is certain this can work, any feedback is good, im trying to u the compression, i have a
huge enough turbo as it is, not happy to bog it down even more.
Wouldnt be much meat left in the head after you had milled 2mm off it.
Why not just buy some CP pistons :-)
You would need to take about 2mm off the head to get the comp up from 7:1, Why not use an rb30e bottom end, you start with a much better comp ratio.
the acl im using were designed for the hybrid conversion, the engine builder that im using had them from a previous build that didnt happen, ill have to see what the comp works out at, but they are practially flat top, so ill have to post it when i figure out the comp
ACL DONT MAKE THEM
as far as i know acl dont make them...however they do make custom pistons i think...so unless that engine builder got them made to suit the conversion especially for that job? That is possible.
Where can they be ordered from? Dropped the motor in thursday arvo and just need the throttle cable and i/c piping fabricated :D
Sorry no idea; i leave those details to my mechanic :D I probably wont see him till Friday, and by that time i'll probably forget to ask :)
Nice looking engine bay! :(
just responding about the comment about shaving my head 2mm to raise the compression ratio from 7:1 umm, what would that make my compression, i got this rb30et motor comlete for an absolute bargin runny rebuilt. which is why i want to try use this.
would it improve much in commpression?
its a waste to replace pistons on a motor that was just rebuilt for CP ones. and the cost of the money involved
id love sugestions
Sorry no idea; i leave those details to my mechanic :( I probably wont see him till Friday, and by that time i'll probably forget to ask :(
Well my memory didn't fail me this week :)
My mechanic gets his custom cables through Speedscrene, link below:
Speedscrene Homepage
hey guys wats up, my thread got closed cuz hey, theres this one. so here it is.
i just sent my car in to do the 3.0L but as far as i know little info is available with r34 motors.
was wondering if anyone could give me some tips as to wat to epect or prepare for.
the cars currently got a few things going as well as the motor being ripped out for inpecton
heres the list so far
gt35
plenum
throttle body
injectors
clutch
manifold
dump/front pipes
cams
rods
pistons
not sure im specs but its just to give u an idea. any thoughts on problems or hassles i might run into?
ash closed ur thread caus u didnt read THIS thread. as per his post all of the info u need is in this thread, dont be lazy and read it, like everyone else had to :)
:P ill get back to u in a few years then.
nah seriously, ill have a read thanks
You've got the plenum and all the bits so it will simply bolt together with a few small mods to powersteer brackets, dump pipe etc.
As for what to expect.. 'possibly' earlier spool and more power everywhere.
You've got some one else doing the job so expect to be broke by the end of it. :P
You sent your car in for a 3.0L conversion and you don't know what to expect? Are you made of money or something???
u wouldnt believe how good i am at my job :P
You've got some one else doing the job so expect to be broke by the end of it. :)
AHAHHAHA i didnt mean wat to expect as in power figures.
as in will i run into certain problems having the 3.0L
also i have been talkn with a friend about possibly getting rid of the 25 head and slammin in a 26 head, resulting in not buying a plenum(save 1k) and selling the motor as a whole to have some $$$ in my pockets.
does anyone see this workn?
Edited by R34NRG
Ahh so you don't have a plenum. I skim read. :P
Its difficult to find a decent 26head for a 'reasonable' price.
Stick with the R34 head, nothing wrong with it. It runs solid followers which is a big bonus.
But yeah depends if you can source a decent 26head without being too out of pocket.
There will be no problems. Its an easy conversion in the RWD.
Technically you shouldn't be charged a great deal more compared if you were going to swap another rb25 bottom end under it.
The only real mods off the top of my head for yourself will be the powersteer bracket, dump pipe, drill/tap of the upper tensioner, run the VCT oil supply, block off the block to head vct oil supply, run a front oil drain.
So not a great deal.
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
