Anyone care to tell me how to get my standard dash tacho working? Im running Autronic SM4, do I just interface the tacho wire from the Autronic to the wire from port 7 on the standard ecu? Surely I cant be the only one to encounter this when not using standard ecu. Cheers!
ACTUALLY I STUFFED UP.
Sorry, I've been hammered on morphine for the last 2 weeks. It has to go OUT 1-2mm to ease the tension a little.
Correcting other post now.
Sounds like your back is still giving you trouble; sorry to hear mate :teehee:
Best to move back to Melb, it's nice and sunny down hear ;)
PS: I also agree with Geoff on the tensioner location. For the new block, we have moved the bolt hole another 2mm across, away from center.
Thanks for backing that up al cheers.
Now ive rung nissan to get a VRS kit for the Rb26 head but nissan want to know if it is before or after the 3/93 with the latter option being cheaper. I havent heard too much talk on here about needing one or the other so im guessing both are the same?
thanks fellas
Just out of curiosity what would be involved in fitting an RB25/30 to a 180sx???
A rough price estimate would be great too if possible...
Thanks.
Front face plenum, lower the mounts as discussed in this "small" thread, move the power steering lines if needed, put a small love bump in the factory bonnet or get a aftermarket one.
Price.. depends how far you go..
I started mine at the start of this thread and I am only just now doing the final touches now. :D
Question about the PowerGrip belt and the Harmonic...
when i fit the belt it sat wonky like the pic below
but with more tension it sits in fine.
Gates state that they supply 2 types of belt, a standard one and the one above which is their "performance" belt.
Not sure if its a case of this belt requires more tension than standard.
Has anyone fitted the 1200 8MGT (says gates on the belt not dayco) and run the car with no issue?
There's previous posts about it but no result.
Thanks
Edited by silver gts-t
If you look at the 30 head you would notice that the way the valves are arranged they sit on one side for the first three and the other side for the last three. In the end its just cheaper for Nissan to make the one set of pistons with the cutouts there rather than two separate designs.
Anyone??? Surely I cant be the only one who needs this info can I??????
wat parts would you need to make a 30/25 combo around 300rwkw and how much roughly
cheers
Tried searching? or trolling through the RB30 threads? oh.. maybe even look at the RB30 dyno results thread! shock horror!
looking at my rebuild kit today something struck me, why did nissan make the pistons to suit a 4 valve head? By that i mean the piston has the cut outs for 4 valves.
Was nissan keeping an ace up their sleeve :thumbsup:
what pistons are they and price if you dont mind
I've had no problems with my standard tacho, using an aftermarket ecu (wolf 3D). Are you sure something else isn't farked up? Have you tried your cluster or ecu on another car?
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
