Not sure if this has been mentioned...
I recently got my RB25/30 running (last Tuesday). I did the mod for the VCT, however, all I did was grub screw the hole in the head, with no other modification. My VCT works perfect. No oil control/lack of oil issues or anything (this was mod was done on the advice of my engine builder).
Discuss.
u mean to say u didnt do either internal(from buckets) or external oil feed to the VCT solenoid and it still works??
Correct. All I did was the grub screw mod to stop oil/water mixing. Bolted the head on (of course all of this on the advice of engine builder) and it works fine. This has been done on my mates twin came RB30 and his also works.
quick question guys, got a 6boost high mount mani and a gt35r turbo,did anyone have to re -postion any of the front or rear housings on the turbo to position the turbo correctly on the mani.my mani is a t3 flange,fits perfetly,so no problem there!
yes you will need to losen the front housing so you can align it properly with where you want it.
make sure the oil feed into the turbo is facing straight up
thought so cheers!i wont be doing it,just a stupid ? really, but there is no stupid ? on here!
ive just gotten hold of a NA rb30 bottom end and gonna to the usual build, ie rods pistons and so on, just wonder a few things...
1. is there any difference with the rb30 NA and Turbo Crank
2. can the rb30 crank be fitted to a rb25 block to get around drilling and taping holes in the rb30 block, read somewhere that this was possible and if not what is the best way about doing the tensioner for the belt if the pre tapped hole is not there.
3. is there any other differences between the turbo and NA rb30 block itself.
Using a 25 head, cheers for any help :)
Edited by fomby639
no
no
no, but there is a small difference between S1 and S2 blocks in relation to the flat area where the tensioner goes, the S2 block is a little easier.
Using a 25 head, cheers for any help ;)
Cheers
Gary
Some of the S1 blocks don't have the turbo oil feed drilled all the way through, check it with a piece of wire and make sure it goes all the way through the block and into the gallery behind the oil filter housing. You can drill it, just need a long series drill to do it. I've only seen one block like that but it's worth a check.
hey guys! Sorry its been a while have been so caught up with work and studies haven't really had much time to spend online or on cars sadly :banana: But i have managed to FINALLY get mine trouble free and tuned. How is all the rb30's out there? Hope all is going well for the festive season.
On a quick note has anyone has issues with the speedometer drive/cable on the bigger rb25det gearbox? For some reason my gearbox keeps shredding the plastic part at the end of the drive, It was all fine until i took it out onto the open road sitting around 100km this is the second time its happened and was wondering if someone knew a way around it?
do most of you guys get more area welded onto the head on the front water gallery i think it is how its different from the rb30 block? i got my head rebuilt but didnt know about getting that bit modded to get more gasket sealing area there. will it be ok to leave it how it is?
its a rb25det head from a r33
Edited by joe blo
How closely are you following the writeups for the speedo sender? are you cutting a new groove and rotating the sender 180'?
too be honest i didnt know there was one lol. Um i was thinking maybe it was because of the bigger motor it was doing this? I have yet to pull the speedo drive out a second time to confirm that it has chewed the plast gears, cutting groove and rotating???? I'm not aware of this
Read the writeups!!
You basically need to rotate the sender 180 deg otherwise the gear mesh is too great and it chews the gears out.
  • 3 weeks later...
hey people, great thread this one has been a great read!!!!
i am just about to do the following
put series 2 stock rb30 bottom end, with new bearings and piston rings
onto a stock series rb25 head.
how much should i be charged for this in labour? i have benn qouted $2500 nearly $3000
bear in mind this is to keep vvt also
any help and advice on whethter this labour price is good please let me know, i think its way too much
Guys I was just doing some casual reading AGAIN on the RB30DOHC guide, and in relation tot heR33 RB25 head, it claims you will need to:
"The R33 RB25 also requires you to plumb in an external head oil return, you can T in to the turbo drain."
What is the external head oil return it speaks of? Is this the standard one at the front of the head that needs to be T'd in?
I'm on my second RB30DOHC motor, and never had this fitted... What issues are normally seen if this isn't plumbed in?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
