I would slap the intercooler on now any chance you can pick up a cheapo nismo fpr by then?
13psi is a fair wack and may impeed tuning as the stock ic will heat soak very quickly.
What has Shaun said he's going to charge?
LOL i could tell u but id have to kill you! :D about a third of tilbrooks, i have a d1 intercooler kit, 600x300x76 with 2.5" aluminium piping ill slap it on this week then, ill let you know what time ill be heading down later next week. Not sure ill have a look into the regulators unless anyone has some cheap 550cc injectors or Gtr 440's and a resisitor pack :(
Edited by FOOLBOOST
Just wondering if anyone has completed one of these conversions with a r34 gtt head, im currently building one with acl forged pistons, and the head measured up to 50-51cc combustion chamber size, just wondering if this is normal or has the head been decked to the buggery?
Adriano, The R34 I haven't heard much about, I believe one person has done it but I don't remember them mentioning any problems they experienced.
What oil/water galley issues are there with the R34 head? Headbolts what size are they?
Cool good to hear! ;) , I took her down on wed to Tilbrook and i wasnt too impressed... firstly they didnt even know my car was booked in at the time they had booked it in and it was just shit customer service, so much for there $75 power run, which they all of a sudden changed to a dyno tune $650-700 on friday which i just lol'd at as they had to get someone else in to do the tune. Pissed me off because they didnt seem to know what they where talking about and i didnt want to leave my car in there hands and pay that much! So i went down to see shawn at BOOSTWORX told him u gave me a hand to tune her so far, he is a great bloke and seems to know what he is talking about. My car is now booked in next friday, which he told me would give me a chance to do some more k's on the motor hence why i chose to get my car tunned there, someone who knows there facts! So if you want to come down next friday if your free, we gonna spin her up on the dyno me and my mate captain thread (helped me build the motor) will be there to see what she can do, Shawn thinks that the standard cooler will cause a bit of a problem, what do you guys think i am only aiming for 220rwkw on 13psi which is what my wastegate is set to at the moment ;) I do have a front mount i can put on before next week its just i was going to wait a while and do them all at once, then i had the following upgrades in mind, Q45 AFM, Q45 TB on front facing plenum, FMIC, 550cc injectors.
Can i ask why you chose to go to tilbrooks in the first place? If you'd asked myself or Cubes or Bl4ck32 we all would've told you to go see shaun.
lol.. the mad rush to get it done..
Think you'll have injectors in by tune day?
Wiring in the resistor pack and replacing inj. plugs/boots took my slow arse the good part of a day.
Using the PFC's inj. trim it started and ran perfectly, all though at full throttle it instantly went richer than 10:1. Afr's off boost and idle were near perfect.
Hey guys been a long time follower of the thread, currently building a 26/30 combo,
How can i find out how much i can shave the head by to bring up CR when using a 280/10.5 cam and Arias rb30 pistons, also has anyone had any experience with these cams i am guessing they should kick in about 4500rpm?
Cheers
Jon
A very good mate of mine has had his car tunned at Tilbrooks and it goes very well and is reliable, hasnt had a problem at all, but my car is now going to shaun anyway...
Just installed FMIC pics below! :D
thats fair enough, i would've done the same thing!
If you get the injectors in time but don't have time to install them give them to shaun and he'll install them for you, from memory he only charged around the $100 and that included all the wiring of the resistor pack etc!
Ok that sounds like a good idea :P , considering i probably wont be getting the injectors till thursday then it will be a rush to put them in and do the resistor pack and i probably wont have it finished in time as something will go wrong as usually does when you fiddle with cars!
Ok that sounds like a good idea :nyaanyaa: , considering i probably wont be getting the injectors till thursday then it will be a rush to put them in and do the resistor pack and i probably wont have it finished in time as something will go wrong as usually does when you fiddle with cars!
very true, do you have a resistor pack?
also what sort of power numbers are you going for?
Reason i ask is i'm only making 228rwkw's and my GTR injector's sometimes get up to around 88% duty cycle, With a Fuel Pressure regulator you could probably push it a bit past 250 rwkw's but i doubt much more.
Mind you i still have the standard crappy rb25de (non VVT) cams so with any luck some new cams and cam gears might pick myself up a bit more!
Cheers
Jon
Hi Jon, you have to measure the combustion chamber size. Every RB cylinder head is different and every individual cylinder is different.
In my opinion 280 degree cams (particularly inlet) are too long in the duration for an RB30. Based on what I have seen on several engines, 280's don't work efficiently until 5,500 rpm, which is too high for an RB30. Unless you are aiming for 800+ bhp of course. The max duration I would use is 272 for the inlet, even 264's work great for a raod engine You might just get away with 280 on the exhaust, it depends on what you are going to use the engine for.
:nyaanyaa: cheers :rofl:
Nope im in the process of getting a resistor pack :rofl: got any spare? My external wastegate is set to 13psi so i think the max ill be making will be 220rwkw if that as my compression is only 8:1, hence ill be able to run higher boost and more timing giving more potential power output once i get an EBC and some bigger injectors! :nyaanyaa:
[Hi Jon, you have to measure the combustion chamber size. Every RB cylinder head is different and every individual cylinder is different.
In my opinion 280 degree cams (particularly inlet) are too long in the duration for an RB30. Based on what I have seen on several engines, 280's don't work efficiently until 5,500 rpm, which is too high for an RB30. Unless you are aiming for 800+ bhp of course. The max duration I would use is 272 for the inlet, even 264's work great for a raod engine You might just get away with 280 on the exhaust, it depends on what you are going to use the engine for. ]
Thanks SK
Sorry for some reason i got 280 in my head checking my msn history its 272, what i want to do is, i got a gt35/40 with a .82 houseing i was planning on the turbo to be spooled up buy 3500-4000, then the cams kick in about 4500, so basicly offsetting the "lightswitch" type power of the turbo by making the cams come in a bit later, giving it some time to grip.. power wise hoping for 650hp ish so using the gt35 to the max (well for dyno runs)
1) will i have to upgrade the lifters to work with the 10.5 cam
2) And How do i identify what type of retainers i have so i can order the right JUN cam kit?
3) What pistons give a 9 ish cr? with the 26 head or do theyb have the be custom made?
Cheers
Jon
Edited by kastin
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
