  • Replies 87
i got a hks to4z on a 26 making 360kw on only 15psi and revving to 6000rpm (fuel issues above that), booked in for new tune now as i found the fuel problem. 10 000rpm limit should see around 380-390kw on same boost :laugh: then ill wind it up to 22psi or so and it should be interesting. thats only the 0.81 housing too
Edited by CruiseLiner
If you want the 400rwkw.
T04Z, it'll get upto around 440rwkw from what information has come around thus far
The GT35 will do it, but its going to be asking a lot of boost from it where the t04z is a lot less
You'll need a flag load more than 24psi to get 400rwkw from the GT35 mate.
Have a look at what people have posted, and also in the RB26 dyno results thread.
Most t04z equipped cars are making the 400rwkw on around 24-26psi with the other associated gear.
yerp mite have to go the 1.06 exhaust, i think sydneykid had one making :
___________________________
Calcs..........
632 bhp = 472 kw less ~60 kw (2wd) = 412 rwkw
The average power from 4,000 rpm to 7,000 rpm is massive and it's not straining at all. A/F ratios are not over 12 to 1 anywhere and the knock is less than 20. Cams and a bit more airflow (no more boost required) it would make 500 rwkw easily]
Ah the old RB30, used it in the car once and then someone paid me enough for it so I could build a bigger and better RB31DET. The GT35R had a 1.06 A/R turbine, with the T4 flange. The compressor A/R was 0.70. Boost was ~1.7 bar (25 psi), the dyno graphs went with the engine as part of the sale
______________________________
see what r33_racer comes up with...bugga hey
so my next question is where do i buy exhaust wheels from?
Edited by kastin
that dyno is known to read maybe a few kws more than others here but definitley not in the vicinity of 80 which i would have thought the limit would have been.
i still didnt believe it however a mate of mine went for a ride in the thing and said it was scary (hes been in lots of 400kw cars before). it did run a 10.8 (maybe 10.6) so that confirmed it for me.
it has stock internals with a headgasket, greddy intake and cams 260's (no porting)
The dyno sheet has no reference to boost... how do you know this then?
Its 20psi its not 450rwkw on PULP.
I wont believe that until i have a boost gauge in my own hand as it runs the numbers, just going by the compressor map will tell you its a tall story.
The MPH would be HUGE if it is indeed 450rwkw.
To many unknowns about that setup to pass it as valid
ok then, ill just post up bullshit for the hell of it.
the same guy (Lithium) on here went for a ride in it and i know the owner of the car. its on pump gas at 20psi running a power fc with map sensor (rb26 one). i didnt believe it but there is the dyno sheet, someone has seen the car run on the dyno and at the drags and its going to be featured in nz performance car magazine sometime soon. proof?
read your compressor maps all you want but at the end of the day all your going to be is an internet mechanic who can argue all day long about something you know little about. ill find out the mph so you can do some calculations or something :laugh:
Good you do that
Cause telling people they can make 450rwkw off a GT35/20psi on PULP with just 260 cams/no porting is a joke and would grossly mid-lead people
We'd better see a MPH well into the 135 range (140 possibly i think).
You'd also better send a letter to Garrett, they'd be interested to know about it aswell im sure.
well on 1.7 bar with our gt3040 .82 we made 375rwkws and 365rwkws on 1.5. After 1.5 it was starting to blow hot air and power wasnt increasing much as you can see.
So i figured with this new motor, with the only differences to the old one is that its now got a dry sump system, gt3540 .82, and 4" exhaust. We should be able to crack if not get extremely close to 400rwkws.
Am i being a little too optimistic?
Heres a link to the site showing the Japanese Performance r33 SirRacer is talking about, it has the list of mods and times ,it states it runs a gt3540 and makes 450rwkw on 19psi but it dosent say what a/r, all it says is (secret a/r), it ran a 10.65 @ 128mph,(mph seems a bit low for the rwkw) when i saw it the day it ran that time it didnt look to even to be stripped, it was just a boring plan looking r33 with slicks.
http://www.japaneseperformanceparts.com/ni...det-p-4409.html
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
