FS: 2 x R34 N1 turbos. - SOLD
Their reputation is excellent! Ball baring, steel wheel, will pull over 300rwkw on GTRs.
Price drop to $2150
Location: Melbourne, pick or i can arrange for delivery to anywhere in AUS.
Model Number: 14411-AA403
Edited by gexenon
anyone wanna give me a loan?
premo: no more rubbish posts in for sale pls. that's twice today. next one = warning level increase.
Beer Baron.
  • 3 weeks later...
hey mate, can you look inside the compressor outlet and tell me what number is stamped in there. should be a 2 digit number either .48 or .60. and what is the corresponding number on the rear. should be a .64 or similar.
Done,
Compressor is .42
exhaust is .64
So what exactly is required with these turbos to fit onto a GTR32? extra gaskets? will the oil/water lines feed up?
Also the wastegate actuator line feed is bent on one of the units, will this affect flow?
Can you verify in anyway how many km's these units have done?
I'm pretty interested, got the money here.
Edited by pisana81
I'm not exactly sure but these will need new gaskets and thats it. They are bolt ons.
They have done 500kms.
the actuator is like that.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
