now lowered! :(
ITS TOGETHER AND STARTS AGAIN! :( Sounds tuff with the new exhaust manifolds,and exhaust (3.5 inch half the way then 3 inch )
these are shots taken under the car at the rear, you can see the bottom of the fuel tank, the fuel pumps ect. You can see the bushes on the srung steel bar holding the diff are aluminum,the diff twisting under take off would mash the bushes, so turning up new ones to make it solid was the only way to beat the problem. B)
The motor is has returned, all pumped up and ready to go,missing Summernats but ready for power cruise. Manifolds have been coated, heads ported ect,ect.HOW TUFF DOES IT LOOK! :lol: I FEEL AS IF i HAVE SWALLOWED A BOTTLE OF VIAGRA PILLS WHEN I SET MY EYES UPON IT :yes: R B's who :lol:
P.S note the intercooler on the front of the mistu, just can leave anything untouched. :Dimgp0053mt1.jpg
you are going to want one of these! full aluminum center consol,REAL RACE, BUILT TO KEEP THE WEIGHT DOWN B) B)
https://www.sau.com.au/forums/topic/155875-convertable-v6-turbo-260z/
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
