sup
forgive the stupid question/noobness. but do rwc joints usually pick on such things?
i went today to about 7 places and they all gave me the same farkin answer "come by tomorrow or wednesday"
anyway, at one place the guy just took a very quick look at the car and spotted these 3 unroadworthy things.
going tomorrow to a...umm...a..."special" rwc place :P:) and get this over with but just curious...
bit tight don't you think?
dirty headlight
don't know if you can see it but the very thin line under the p-plate. bottom left corner of the p-plate (dirt)
dirt blinker
https://www.sau.com.au/forums/topic/155989-do-these-look-un-roadworthy-to-you/
as long as they work i dont see anything wrong.. If a windscreen is chipped or cracked its un roadworthy or moisture in headlights/tail lights
they all work. the line on the windscreen is just dirt that doesn't wanna come off too easily. whatever that is on the headlight, it's inside but it's just as good as the other one when light is actually turned on...
Those headlights are pretty bad and I have seen various EL Falcons, etc, fail roadworthy in similar or worse condition. As previously posted, try to use cutters and buff the headlights, but remove them off the car first and take care not to burn the plastic.
Windscreen can simply be polished off, by a professional glass polisher.
Tail light is tricky as you have a moisture issue, thus have a build up of dirt/grime inside the light assembly.
Think yourself lucky. Many years ago, to get a roadworthy, you HAD TO replace the windscreen. Without any form of measuring equipment, they always deemed that a (used) windscreen did not meet the standard for light transmission.
yeah i guess it's not all too bad but remember this was just a very quick look it wasn't an actual inspection.
i went this morning to a different place, didn't notice these little things but came up with this list:
l/h outer e/v boot split
r/h outer e/v boot split
radius arm bushes
he said it would cost $275 to replace these with new ones. does this sound right? already wasted $100 on the inspection.
still cheaper if i was to get a "special" rwc :kiss:
Edited by R-SPEC
what the hell is an EV boot.. a CV boot?
try ringing Chris @ Centreline for a 2nd quote 94692914. They're just off Mahoneys Rd and won't rip you off.
PS $100 is a ripoff.. I hope that was for 2 x $50 inspections at different places. Don't forget that if you take it back to the same place within the 30days you do not have to pay another inspection/RW fee.
how does that work? did they have to fix something or put in whiteline bushes? I think from memory their alignments are $90 for 4 wheel.
Edit: There you go, Michael said a camber kit is about $300 or thereabouts with an alignment.
Also it was probably a Whiteline kit, and Centreline usually charge less than if you buy direct from Whiteline.
You can have a look at one of Sydneykids threads to compare prices for the kits.
well being that I wasn't there and don't know the full circumstances of the problem, I can only suggest you look at the receipt and give Chris a call if you don't understand what was done to the car and what you were paying for. Chris has always justified what he has done or what needs to be done to our cars and the price/quote even without being asked and to the point of him giving me back the broken parts without asking for them.
To me it sounds like something else was obviously fixed/replaced and Justin isn't clear on what he was paying for.
hehe
nah dezz was with me at the time cause he got some work done on his car earlier that day.
aparantly... the camber on both wheels on the passenger side magicaly changed cause i had a big side on accident.. evan though theres no damage on my car... or on the wheels.. anyways
he goes "its going to take 2-3 hours to fix and cost a few $100"
and 30 minutes later the camber had the correct settings again.. and i was down $300
he evan said to dezz "your friend must of had a big accident"..
my theory is... 2 ppl installed all the suspension stuff originaly.. 1 on each side...
the guy who did it on the passenger side didnt do the camber properly or something...
radius arm bushes
still cheaper if i was to get a "special" rwc :ninja:
:rofl:
Agreed.......
Sorry Justin, i still find your story hard to beleive. I've been to Centreline, many times for different things, Chris is currently sorting out a set of coil-overs for my car, and i have had nothing but top class work at good prices.
It's strange how almost every person that works on your car f**ks it up or rips you off :) ; even though many others have never had issues using the same business.
If you still have concerns/issues, (and you obiously do) why not approach Chris and ask for clarification on what was done in those 30mins :huh:
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
