After many many years of wearing bloody helmets it all comes down to you. Not every brand of helmet will fit you properly. Chicks get it a lot easier because of the lack of a protruding adams apple. I would suggest picking a budget,,,adding 300 bucks and go try heaps of them on. You will known straight away as soon as you put it on and tighten it up if it right for you.
For the record I have owned Simpson, AGV's, Arai's,,,cheap crap and am now wearing a Bell Vortex Ultra which is light and comfy.
My wife made me spend so much money on it,,,I get nervous when the scutineer has it in his hands.
Remember try heaps of them on and don't just go to bike shops and Revolution,,,try some other motorsport shops. I did buy mine from Rev but I was lucky as it was on special.
Neil.
https://www.sau.com.au/forums/topic/156168-helmets/page/2/#findComment-2920276
  • Replies 85
Hmm, interesting. I cannot fault my Jet 2 for quality, so am not quite sure what you mean by that. It fits me nice but then again everyones head is a different shape.
The Jet F is a more recent model than the Jet 2 hence the availability of Hans pegs.
Make sure when they turn up that you look inside to see the safety code the helmet complies to. It will either be SA00 or SA05. If it is SA00 hammer them on price because it will be old stock. The helmet is still perfectly compliant and useable, however.
sorry not quality but shell design different. yep mine is a SA05.
https://www.sau.com.au/forums/topic/156168-helmets/page/2/#findComment-2921705
:) Mine's a HJC cl14, only a cheapy to get started, but is snell,dot & aust. standard approved.
Fairly light, nice & comfy & is suited to my big noggin.An american company, that's why they make 'em for big heads apparently!
At around $250-300 i think good value for money & really happy with it so far.Plenty of plain colours & graphic styles to choose from...
https://www.sau.com.au/forums/topic/156168-helmets/page/2/#findComment-2923844
After all is said and done, its a helmet. designed to keed up your head from looking like a busted watermelon in an accident. Try (if you can) to get the very highest quality you can afford, ask yourself.. what is your head worth to you?
Bear in mind that some motoring organisations require a set standard of hemet. make sure u exceed this standard and check out what other motoring bodies use as their standard. You never know when you may want to try something different with a mate or something..
You don't want to be stuck in a situation where your helmet is the only thing stopping you from doin somethin new! Even though it is a great helmet..
any other thoughts.. :(
https://www.sau.com.au/forums/topic/156168-helmets/page/2/#findComment-2930849
I agree with what you said psi. I would spend as much on the helmet as I can afford. You see people go off and spend 5k on car mods, then be stingy and pick up a helmet for $100. Is your head only worth $100? It must be if you're that stingy to spend that little on it.
Keep in mind that if you are collided from side on, your head WILL hit the window. Head bashing window = bad.
I'd much rather have a good helment protecting my fricken head, than some cheap arse one.
If you've spent 5k plus on car mods, I don't see why a helment worth anything up to 500$ isn't too much
https://www.sau.com.au/forums/topic/156168-helmets/page/2/#findComment-2930872
Just to disagree with everyone, I just buy cheap and well fitting. Under $200 for me.
Its nice to say "if you have a $2 head buy a $2 helmet", but don't forget even the cheaper helmets are AS approved, and I've never heard of someone who died wearing a cheaper AS helmet who would have lived with a $1k lightwieght super stig helmet
https://www.sau.com.au/forums/topic/156168-helmets/page/2/#findComment-2944821
Fair enough Duncan, as you say, cheaper helmets MEET the required standard, but I am one to assume that more expensive helmets (discarding the fact that in many instances, you are no doubt paying a large portion for a "big name"), not only meet, but EXCEED the required standard.
Another issue to keep in mind is that a lighter helmet has less kinetic energy in an accident, therfore there is less chance of neck over-extension damage, particularly in a frontal impact situation.
Cheers!
(p.s. not long 'til TARGA!!) :P
https://www.sau.com.au/forums/topic/156168-helmets/page/2/#findComment-2944858
so what helmet are you using? :P
https://www.sau.com.au/forums/topic/156168-helmets/page/2/#findComment-2945174
very good point. and is the reason I bought the cheapest carbon/kevlar helmet I could get. it's around 1kg. :ninja:
https://www.sau.com.au/forums/topic/156168-helmets/page/2/#findComment-2945189
You buy cheap cause you are cheap. I remember you cost me like 2 bucks the other night. 2 buck helmet for a 2 buck head.
There's no way you can convince me a cheap crap helmet is as safe as a high quality one and neither is the fit or quality of the lining. I'll be interested to see what helmets you buy next seeing as how your current ones are just plain tragic.
Neil.
https://www.sau.com.au/forums/topic/156168-helmets/page/2/#findComment-2948691
absolute rubbish. In fact the only reason I am getting a new one is because I didn't have a helmet bag for the first few years and I scratched the crap out of the outside.
It has been used heaps, still fits well, no trim coming off etc.
And like I said I will be going back to a motorcycle shop and picking whatever is cheap and comfortable again.
https://www.sau.com.au/forums/topic/156168-helmets/page/2/#findComment-2963128
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
    • ^ This. The mode door actuator is a common failure, as is the actuator and/or the actual valve for the coolant flow control valve. I also don't know how available the mode door actuator is these days. I've been meaning to look into it and get one from wherever is possible, to keep in the shed for the rainy day when mine eventually fails. Anyway, the advice to you is to search the usual NOS part supply places, or even just go to Nissan and see what they list.
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
    • I'm happy with the Lsailt unit that I put in, it puts full Android on the top screen so you can run whatever Nav and other Apps you want, while still existing inside the factory functionality like automatic reverse cams, audio input switching, retains factory bluetooth etc. Not cheap and the install was moderate (not simple, not hard) Yours is a V36 not V37 though right?
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
