It's not 75%
It's a set RPM determined by the EPA - which is more than that.
Either way, you need to be 89dB @ 4900rpm - that includes on back off/rundown. Which is usually what trips the meter.
Unless you have a stock exhaust, you'll fail.
My memory is hazy on this, but I thought it was around 60% of peak RPM (based on the factory limit) at 500mm at around 45 degree off axis with minimal reflective surfaces during the measurement (the meter must be away from reflective surfaces.)
Can't remember where I had this information though, so not 100% sure it's right...
EDIT: actually I thought it was 50% of max rpm...
Gotta find the EPA doc...
Edited by wht510
Well.. If he said you'll get it in the mail - guess what? You'll get it in the mail :merli:
You really need to have a read of this thread. It'll give you a fair idea of what you need to change.
You'll only need to change the things that can be picked up. ECU is obvious, you already know that. So what else does the ECU control? Injectors, AFMs etc. Only stock items can run on a stock ECU etc.
It's not 75%
Unless you own a gtr which when it rolled out of the factory in japan was over the 90db limit for Australia ... go figure that one out.
A while ago i read there was specific areas that are exempt from height rules, from what i read it was a meter either side of the axles, downloaded the mod guide from vic roads to check and there is nothing in there any more, it is a new one too, october 2011 is the date on it now.
Last time i looked at it exhaust manifolds were free as long as all the original fittings were retro fitted, now you need to have documents from the manufacturer to say that the manifold you are using is suitable for that car/engine, im glad my chinese stainless manifold cracked and i went back to standard.
seems things are getting worse
Edited by W0rp3D
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
