hey guys iam lookin at getting a new turbo and boost controller but forget about the boost controller at the moement. I saw this turbo http://www.justjap.com/jjr430.htm and it is cheap and appears to be pretty cool to bolt on to my r33 gtst. I just want to know can this work and is this turbo any good? i also looked at the sliding performace turbo and people say that is a good turbo but this one cheaper. I am not 100% on the in's and out's of this type of upgrade but i want to hopefully achieve 200+kw at the wheels would this turbo and boost work? i currently have about 160 at the wheels with safc 3inch hks exhaust hks pod filter hks intercooler SAFC hks ssqv with 7psi boost. Thanks any help would be nice.
https://www.sau.com.au/forums/topic/156592-turbo-upgrade/
It looks to be a re-badged KKR430...
so what is the best price for a kkr430 on the net? also is this a direct fit will it bolt on and replace the stock turbo?
also if i got this should i upgrade the fuel pump to something like a bosch 044? or would it be fine with the stock one? would i need to also change injectors to get the target of 200 or more kw? or can it live with stock engine and still perform well?
thanks!
https://www.sau.com.au/forums/topic/156592-turbo-upgrade/#findComment-2910667
After you add in the cost of a dump pipe,
silicon hoses, oil and water lines etc. to fit
this turbo cost would end up being pretty much the
same if not more expensive than a slide turbo.
If you already have a bigger dump pipe it will bolt straight
onto the slide turbo.
There will be more mucking around to fit the jjr turbo too
https://www.sau.com.au/forums/topic/156592-turbo-upgrade/#findComment-2911032
Just jap seem to be doing this a bit lately, they have a number of products that are brand named jjr, but they look just like the ebay chinese copy specials eg jjr external wastegate, it looks like a hks unit, and there are a myriad of chinese knock off's that look exactly the same on ebay.
I'm not saying they are no good, I'm not saying that they are the same, they look the same. And they are at bargain prices.
https://www.sau.com.au/forums/topic/156592-turbo-upgrade/#findComment-2911590
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
