I want your Neoclassical kit :/
Currently making them up for a dealer, will be flares, stickers and a few other options we have been asked to look into, exterior and interior.
I'm just organising people I know to make them, if wanted will be direct from manufacturer so no Butt Tax for doing nothing.
  • Replies 508
Woah, there'd be lots of people making copies. Iron Chef and Topstage have mentioned it.
They are not something to make money off and making plugs then moulds isn't cheap, the people buying them off my mate will buy locally even if it cost's more. Below is what is made on a daily basis and that isn't going to be put on the back burner for a few Cube body kits. Kits will be made in batch's of 5 other wise not worth wasting his time.
I do sign writing as a side line and a few stripes with CUBE cut out of it isn't anything special.
dunc. HGE 80X is the winner. kel won't mind. it's not about her, it's about the car dude! my silvia is box 88. (hako = box in japanese). I love the box.
  • 3 weeks later...
Ha, I didn't even get it at first and when you do... well it's obvious what box it means :laugh:
I agree HGE 80X ftw
No.. Is called the Toyota rukus
corolla runion actually :)
yep they stuck the Bb on the list. no one is doing it as I understand. its not the first model though.
see also diahatsu Coo. that one IS on the list and there IS some one doing it and its the same as the Bb.
Like Chris said, the Rukus is based on the Corolla Rumion, not the proper bB, which is a good deal smaller. I'm struggling with the first-gen bB application because boxy profile was one of the criteria I used to get it through - they knocked it back now the Rukus has been released...
Question - looking at getting a Cubic to replace my wife's Grandis. Need something a bit more economical and easier to park/maneuvore (nearly every panel on the Grandis, save the roof, is dinged!)
Only thing is...does the rear bench split fold? And if it doesn't, would it have enough room left to fit a pram in the back?
It split folds but there'd be room in the boot normally.
Doesn't look like split folding rear bench to me???
http://www.carsales....&autoplay=false
http://www.carsales....73&tabID=304744
Is it because you have a series 2?
hmm 2005 1.5 YGZ11...still no split folding bench?
http://www.carsales.com.au/Tig/UI/PagePopup.aspx?R=9136671&PhotoID=9102018&h_mid=4415219&f_mid=&c_mid=4414491&pid=140973&tabID=304744&autoplay=false
Edited by ironpaw
on the Topic of Rukus.
I drove it for a good hour to the city n must admit, a very good car! its has power comfortability and a shite load of room!
i loike it
It doesn't split fold but there's plenty of space for a pram with the rear seat folded down. I have two friends with young kids and Cubics doing this already.
Yeah...the only issue is I have 3 kids, and fitting them all in the middle row would be very tight. What's the middle row width wise like compared to my M35 Stag?
Looks like I might need to see some local samples...
If you're only running one child seat, you should be ok to use the other two seats in the middle row. Either that or fold the middle seat down on one side, chuck the pusher on it and put two kids in the rear seat. The middle seat in the middle row is only a lap belt, so we've got a harness if we ever have to fill the car with kids.
  • 1 month later...
  • 1 month later...
    • I’m here solo don’t have any hands to help so haven’t hit it with a timing light
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
