Does anyone know what these guys are doing after????
say around 8-9 pm ish....
unless theyre all goin home after a days thrashing :(
jus wanna catch up wif em and c how it went and if it sounds fun...then count me in for the next one
was there anything planned afterwards???
  • Replies 175
WHOOOOOOT!. Who said wheelchairs cant fly. Did a best of 13.8 tonite. COOOOOOL!~
Ben ran strong all night posting some good 13.6's at around 110 mph. AD_N finally learnt how to launch a gtr and ran some strong low 13 second passes. Big Chris did a pb in the 4 door auto taxi.
There were a lot of lines there tonite, some real sleepers too. hot gtr running 11's, super sleep gtst plain white no wing no nuthin running low 12's in the 120 mph bracket.
Young Andy had his first taste of the drags in his new 32 and had a ball. I think he got dizzy from just going round the loop to do another pass. He's hooked. Devils advocate Adam borrowed my lid for a couple of passes and showed how to break traction in 1st, 2nd, 3rd, 4th. Thank gawd he ran out of road cos i think he may have lit 5th up too.
What a great night. pb's everywhere and lines galore so to all of you that said you were coming then found your yellow blood count was too high I say....Stiff shit. You missed a great night of lines at play.
Did a best run of 13.38 at the end of the night! so pleased with that. had an awesome night thanks Noel for dinner. stoked you got your 13.8 well done, gem might put some pics up later.
13.38. !!!!KEEEWWWWLLLL Ben. you gotta be happy with that man.
haha did adam have his cheese cutters on the back did he? :)
good to see he hardened the f*ck up :(
much of a crowd there this week?
yeah it was busy courtesy of a harley day but once they f**ked off it wasnt too bad. Toward the end of the evening you could get about 4 runs in half an hour if you wanted.
As happy as you were with yours, should organise going on wednesday nights, get some more runs in.
Wednesdays rock Ben. I think we maybe should try and organise at least one wednesday line night a month. i am definitely up for it.
Yes i love my no traction tyres they were awesome, only got two runs in, First time doing this shit pulled out a 14.7 on the first run with 1.3 reac and 2.7 60FT cant remember the speed, 2nd run bit better 1.1 reac 2.3 60FT 14.1 sec quater at 106 mph too much wheel spin damn it lol, and that was in line with changing at or before 6000 rpm, meh good base to work at
Nice night out, really enjoyed the 8 second action from that Series 6 RX7... WOW...
Got to catch up with the regular TnT gang...
Plus I got valuable info from the on of the ford boys on tyres and rims to use for my car as he had a similar power output...
He ran a 11.09 @ 129mph with a 330rwkw XR6T and made some huge smoke :( so I think i know what ill be buying now...
FYI ----> MT ET Radials 255/60/16 and run about 17-18psi tyre pressure...
Edit: Ill add some photos later...
Also I have to add, there was no accidents and no stops tonight...
So it was one of the best Saturday night events ive been too...
Apart from the Harley Boys getting preference all the time and getting like every second run (but who would complain as they are big, hairy and have many tattoo's), once they left the runs seemed to flow nicelly... Adam (devils) you left too early, you coudl have got another 2 or 3 in before 9pm...
Arrrr well...
Arrrr well...
thats a good call Col. The last 30 minutes was like happy hour. Just go round and round as quick as you could and get in about 4 runs in 30 minutes.
Nice. I didn't even realise there was a SAU club day on and saw all you guys out there. I ran 12.1 @ 124mph. I wasn't trying for ET, just wanted to see what sort of MPH I could run as I know a good ET was never going to happen with a stock stall converter and large turbo. Just need to get rid of that stock stall converter, fit a less restrictive exhaust and aim for low 11's - high 10's. :(
Which was your line dennis?
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
