it may not be factory, but i have seen one before on an R32 m spec. it was making 210rwkw. also came with the electric spoiler.
I thought it was factory.
the one i saw was exactly like the one listed but also had a shroud. it is not a backyard job. look at the end tanks and mounting hole.
Still looks the goods to me
overall heat transfer coefficient for a wall can be calculated as:
1 / U A = 1 / h1 A1 + dxw / k A + 1 / h2 A2 (1)
U = the overall heat transfer coefficient (W/m2K)
A = the contact area for each fluid side (m2)
k = the thermal conductivity of the material (W/mK)
h = the individual convection heat transfer coefficient for each fluid (W/m2K)
dxw = the wall thickness (m)
Aluminium Coefficiant: - 221 W/mK
When aluminium is used as a heat exchanger in ambient air medium
U = 1 / (1 / hA + dxw / k + 1 / hB) (1b)
Taking the total medium transfer to: U = 25.0 W/m2K
even if the air temp in the cores is 70deg C the total increase of air temp traveling thru the second core from the first will be nothing compared to the temp coefficant.
in other words....
it will perform very well.
Well the ARC type are 110mm thick. This is 130mm (2 x 65mm) . The air flows through the fins from frotn to back - shouldn't be a real issue.
It won't be quite as good in cooling as a taller skinnier cooler but it should flow ok.
Might connect up a water spray for hot days...
Way I see it if it can handle 220rwkw I'm laughing.
Benfits:
1. easier to fit
2. looks stock
3. wont lose response like with a FMIC
3. good for insurance etc.
downside:
1.not as good cooling
hmm well i had a r34smic, then upgraded to a fmic (r34 is exactly 61% bigger in core size btw) but maybe i'm not seeing things correctly but that piping (entry and exit points) doesn't really look like it will bolt up correctly to the stock 33 piping?
Maybe its a r32 one? as i recall they have a different piping setup to the 33/34
I put a 34 SMIC in my car, and it pushes right up against the front bar. This thing looks like it would want to sit much further forward?
The distance from the inlet/outlet to the back of the core looks the same as my 33 and 34 cooler, so the extra thickness APPEARS to take more space at the front?
Definitely keep us updated on the flow results! I'm keen to know how much better this 34 cooler is over the 33 one, regardless of the dual-core setup.
cant comment on the stock bar as i've always had a aftermarket one (as pictured in my av) but i did measure back to back the cores (stock 33 vs 34) and from memory the 34 core is a couple of cm taller (so sits lower) and 2cm thicker, but no wider,so would sit a tad forward yes
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
