does ur car have pod and fmic?
if it has 1 of these then its ok. a cold air box isnt creally considered a mod unless ur the cops. i got 1 and i went epa with it, they said it was cool. and coz it was a box (enclosed) and my pod was in there with fmic, that was ok too.
cops dont know shit, they just after bronie points!!
hope that helps
Intercoolers that are larger than standard or have a different mounting location or are added where none were originally fitted, are permitted only if no other changes to the intake system have been made.
In other words, you may have a pod filter or added/modified intercooler, but not both
Guidelines are clear as day.
If someone got passed, they were lucky.
Dont expect it to happen everyday
I was at the EPA the other week and the guy in front of me came in with a cooler and a pod that was it and he was sent away to come back with only one of the modifications.
Was speaking to the guy from epa who gave me a leaflet on what you can and cant do... EPA are genuine and follow the rules and guild lines fairly as they are set out this being one of them...
hmm this guy is going for a roadworthy, not trying to pass an EPA test!
ive been speaking to alot of people who are lisenced road worthy supplier mechanics, and they said thier guidelines for a roadworthy certificate are set by vicroads, not EPA, so i asked them the hypothetical of passing the car with a front mount and a pod filter... and they said, yes because those are not on the requirement list of the road worthy, as long as they are done properly and are safe (eg pod is bolted down) and front mount isnt leaking and is mounted properly, then they are fine!
EPA and vicroads should really get together, sit down and combine thier roadworthy/epa requirements because at the moment they really are two different entities that have thier own rules!
-Ruffels
Edited by Ruffels
Ur point?
Technically what i posted is 100% correct.
RWC, EPA test... whatever.
If your car does NOT pass EPA it is not roadworthy. Most engineers over look this when compling a car, but it does matter.
Ur point?
well my point is, the guy is worried if he will pass his roadworthy or not with his cai box, and from his sig pic it looks like he might have a front mounted intercooler too, and i am letting him know that it most likely will pass his rwc with the two induction mods.... he will fail an epa test, or if i police officer pulls him up on it he will have to change it, however i answered his question about passing his roadworthy... doesnt mean you have to have a stab at me for answering his question...
-Mark
Edited by Ruffels
ffs this gets covered like every day.
Its not legal, but will prob pass the RWC as the form is generic and basic form for all cars.
But, when they defect you and u need to go to the EPA...you will need ot remove it.
Period.
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
