Just wondering if anyone has had practical experience with injectors and rwkw.
Can you use a linear relationship to determine the approx duty cycle as you raise the boost and make more power.
e.g. If you are seeing 70% inj duty ~ 170rwkw
If linear then at 90% inj duty should be ~ 218rwkw (based on quick calc)
And I guess 90% is about the most you want to push it..
Question: I'm going to keep my stock injectors so would I be safer to
1. Just tune till these get close to 90% and live with that (Would that be around the 220rwkw..).
Or
2. Would I be best to increase the Fuel pressure slightly so that the inj duty max 85%?
I really want to get about 220rwkw which will be about a 27% increase in power. I realise I should renew some of the hose to do this..
P.s. I'm going to be putting in a gtr pump to ensure the pump isn't limiting things..
The R34 in HPI got to 90% @225rwkw
http://www.whiteline.com.au/default.asp?page=/reviews02.htm
Edited by benl1981
https://www.sau.com.au/forums/topic/158253-fuel-injector-duty-cycle-vs-rwkw/
  • Replies 45
Posted Images
there is no way you can get a relationship between injector duty and rwkw. thats just silly. every car is different. different pump conditions different fuel line different engine condition / turbo condition / intercooler setup / head setup and the list goes on.
run the fuel pressure at 46psi and use the injector duty up to around 95% absolute maximum which should see between 210rwkw to 230rwkw
Its on the same car though...so I thought you may be able to compare..
Provided the fuel pump etc can hold the pressure.
Yeah - Ill probably get a Nismo FPR and set it about 8 or 10psi above stock pressure. Does anyone know what stock fuel filters are rated at? I.e. how many psi ..because 46psi + 15psi (for boost) = 61psi max fuel pressure
See how we go.
Cheers
Im sorry, i would have to disagree with most of you, injector size is definately proportional to horsepower assuming the same AFR and duty cycle. A ported head or bigger turbo will make more horsepower and require bigger injectors. A car making 500rwkw will need double the fuel(approximately) than that of a 250rwkw car. There is a simple calculation of what duty cycle and fuel pressure will support a given hp with a certain set of injectors, i just cant remember where the formula is.
100% injector duty eek!!!.. hope you got the $$$ ready for a engine rebuild.
lol it's the first time I found the magical 100% I was told there's only 2 or 3 places in the mapping where it reaches it. normally it don't go above 90% but i do drive it fairly suttly at the moment, but these things happen when your showing of to someone :P
Anyway to clear it all up a little better, a better way of working out how much power your injectors will support isn't to look at the duty cycle so much but to look at the actual ability of the injectors to supply fuel. Generally it is more widley accepted with a 2.5-3L ish 6 that for ever 1cc of injectorage you'll get 1hp at the crank, so if your running 600cc injectors they'll safely support 600hp at the engine. If you relate this to my pic above for example, 440cc GTR injectors are supporting 415HP at the wheels but on very high injector duty which is bad. As I always say if you want more power, dun be a tightass just get bigger injectors they ain't expensive....
Exactly, so 370cc injectors at standard fuel pressure have the ability to make 370hp(its actually a bit less)so 360hp, which equates to about 220-230rwkw safely, as has been proved a number of times. Hope that answers a the question.
Most places I've spoken to, and sized up, have managed to work out the correct inj size, and they don't like to run over 80% DC at all!
They leave 20% for spiking etc, and for other necesities, and since using up to 80%, it makes it easier to tune (Rather then a car that only uses say 40%)
HP is almost directly proportional to fuel consumption (BSFC - Brake specific fuel consumption) in spark ignition engines if the same AFR is to be used. What you've got to remeber is that dynamic flow rates and static flow rates from injector to injector are quite different. Most Japanese injectors are expotential flow - meaning their flow rates with low duty clcyes may be far less than their flow rates at high DC ie its not linear.
Aslo accelleration enrichment in 90% of cases wont effect peak DC as once full thorttle is seen there is no more correction.
Don't forget the affect of acceleration enrichment.
;) cheers :wave:
This is the case with my car. If i dont let it warm up it will hit 100%. But after this
it only ever see's no more than 90% duty cycle. The car is a R33 GTST using the
stock injectors with a nismo FPR and is making 260RWKW. It's not a happy dyno
as i first thought because the car was run on there dyno when it was 160kw and
was run on two different dyno's in the space of 3 months and between all three
it varied 1kw.
it varied 1kw.
Thats coolant correction not acceleration enrichment.
lol it's the first time I found the magical 100% I was told there's only 2 or 3 places in the mapping where it reaches it. normally it don't go above 90% but i do drive it fairly suttly at the moment, but these things happen when your showing of to someone ;)
When I was running stock injectors once it hit 100% it stayed there and fuel requirements only increased as rpm did so even if it wasn't making more power. Mine hit 100% duty at around 5200rpm at WOT from memory.
ECU puts more fuel in when cold because the cylinders are cold. What happens is some of the fuel when sprayed in, condenses on the inside of the chamber leaving less available for burning. The ecu knows about this so puts more fuel in when the engine is cold to compensate. It assumes cylinder temps based on water temps.
It's just trying to keep the AFR's where they normally are when the engine is wamed up.
Also has anyone watched a dyno run when the injectors hit 100%? It actually goes rich. I'm told this is because they have given up all pretense at opening and closing and just stay open all the time. This means that much more fuel is put in at 100% compared to 99% than is put in aat 99% compared to 98%.
Never seen that before. Most injectors flow about the same between around 97-100% Duty cycle. Usually you can tell your out of injectors as the AFR will enlean linerarly at 45deg angle.
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
