im in the same position as most of you with pushing the injectors to their limits but for now im just winding the boost down 1 psi and wait for the 600cc injectors and f/pump when i get some more cash then = high psi :D
  • Replies 45
Posted Images
I'd do what your tuner is comfortable with doing. Heaps of people on the forums have made substantially more power than 225 rwkw on stock fuel injectors with a bit more rail pressure.
There's no problem bumping the rail pressure up a bit etc (it is suspected that s15s run higher pressure) than our cars. That's why the injectors flow 440 cc on r33s, but 480 on s15s.
I just wouldn't go running a million psi that's all.
  • 5 months later...
I am making 270 rwkw with stock injectors and stock fuel pressure (and reg.) with no knock issues at all.
I do have very bad fuel economy though, could the stock injectors be contributing to this at all?
Cheers
that's a fine theory except that 33 GTST don't have anywhere even near 440cc let alone 480cc injectors. they are 370cc...
This is not possible unless your fuel pressure reg is busted allowing huge line pressure or you have aftermarket injectors and don't know about it or the dyno setttings have been tweaked :(
Stock injectors and same figures on two different dynos (one being the PAC racing dyno)...
FPR may be busted? Would this be giving me bad fuel economy?
You guys can all laugh, but there IS a definite relationship.
Basically 6cc per minute per flywheel horsepower is a very close approximation of fuel flow at optimum air fuel ratio.
As you have six cylinders, and six injectors, that means max flywheel horsepower = Injector flow at 100 percent duty cycle.
So basically 550cc injectors would equal 550 flywheel horsepower absolutely flat out at full maximum duty cycle. But that is not real smart. You might want to limit it to 80% duty cycle maybe ? Which would be only 440 flywheel Hp.
But then there are drive train losses, typically only 85% of flywheel power makes it to the rear, so that comes to 374 Hp. Converted to Kw that is 275 RWKw.
Depending on the injectors you run, and assuming the fuel pump is up to the job you CAN figure out a reasonable RWKw versus injector size.
So absolutely balls to the wall with no margin might be injector size in cc x 0.85 x 0.746 = RWKw
Something safer and more reasonable might be injector size in cc x 0.8 x 0.85 x 0.746 = RWKw
yes, but that's a relationship between injector size and horsepower, not injector duty cycle and horsepower. duty cycle doesn't tell you anything except for how long in 1 cycle the injector is open for. I can have an injector duty cycle of 80% by I'll be getting very different amounts of fuel between a 300cc injector and an 800cc injector...
Cheers
HAHHAHAHA what dyno....... i want to put mine on and im sure it will run 500rwkw if you ran 270rwkw.
I told you what dyno. PAC racings dynapack hub dyno and also a dynodynamics roller dyno. Have you heard of the PAC boys before?
Well done if you have 500 rwkw, nice power.. I know its making 270rwkw, I am sure that the three tuners and two dynos I have used would not be out.
What ecu are you running?
Those out there who have fiddled with batch injection. Is it possible to get close to that figure with batch fire?
i.e 2 injector pulses per cycle vs the 1 pulse (sequential) the std ecu and pfc uses.
(remembers back to the 533rwhp on stock injectors thread) :huh:
(remembers back to the 533rwhp on stock injectors thread) >_<
just the PFC. I have many people that can verify that its making the power I said and I know that injectors and FPR are standard, only fuel upgrade has been a bigger fuel pump.
ok.
Well as you can understand its definitely not possible to run such figures with stock fuel pressure and injectors.
Have a look at the std fpr and tell me if it looks as if some one has smacked its top in a tad. Its a crude method of upping fuel pressure.
Whats your tuner think is going on? He would obviously have some idea as the base map would be way off the mark if it were running higher fuel pressure and or highflowed injectors.
Bet you have a blockage in the return line and or the pump they are using is massive ie too much flow for the standard reg to flow so you have higher pressure at lower duty cycles as the fuel is not being consumed. This would explain both the shite economy and the large power figure.
*DISCLAIMER*
The below is a loose quote of a conversation between a well-known "old school" Brisbane tuner & myself not long after I bought my GTR. I myself have not confirmed what he said to me & will therefore recommend you do your own research BEFORE attempting this at home.
This guy was involved with the build of my engine & was adamant that std Nissan injectors were considerably under-rated from the factory & I should have no problems flowing enough fuel to create 600bhp considering the hardware already attached. What rail pressure was required to do this was not discussed, but it would have to be a fair chunk higher than std which in itself is not really a good idea. Under bonnet fires fed by leaking fuel delivery systems get real nasty REAL fast......
I do intend to actually test the flow-rates of assorted std injectors vs rail pressure simply to answer the Q of whether this is in fact attainable but only in a test rig & even if it is doable, bigger injectors & lower psi is always going to be safer than smaller injectors & huge psi.
Food for thought.........
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
