OK for all you budding or wannabe mechanics see if you have any ideas on this one..... even if they seem obvious im open to any suggestions!!!!
My car doesn’t idle properly
It hunts when stationary and sometimes goes close to or actually does stall when you lift off the throttle. The faster you lift off and the slower you are going the worse this is.
Its running rich
At the moment it is going through a full tank in 200km as apposed to the usual but not much better 350ish. This seems to be only intermittent though as sometimes you cant see any black smoke and other times there is heaps. By heaps I mean more than the usual skyline running rich on boost from factory.
It is not boosting up properly
It usually has positive boost by about 2500rpm but at the moment its not getting positive boost till more like 3000rpm to 3500rpm. It sounds like the turbo wastegate is opening early and bleeding off boost to early as you can hear the turbo spool up but nothing happens until later in the rev range.
It is down on power all through the rev range
Im sure this is quite obviously linked to the turbo problems.
I have reset the ecu but this had no effect on any of the above problems.
I have also had the air flow meter cleaned,the compression checked and im sure a few other things checked that i forget.
As far as mods go it has a turbo back exhaust, pod filter, front mount although still running standard boost as the next step was to wind the wick up a little but that seeems kinda stupid at the moment given the way its running. factory computer, no boost controller.
Any help would be much appreciated ;)
https://www.sau.com.au/forums/topic/158333-who-wants-to-play-detective/
Its running rich
check/ change the air flow meter first oops didnt see that u typed it but it could be
Edited by R33GOD
intercooler pipework leak
causing some pressure in the manifold to be lost to the atmosphere, gives it a bit of a laggy feeling. its stalling or struggling as some pressure and air is leaking out, so its over rich.
the bad economy could be the same problem or it could be your 02 sensor is shagged. the die and only last about 50,000 k's so chances are you have never changed it, so do that and it should fix your economy.
Thanks for the heads up guys im open to more suggestions as this one's got me stumped. We did clean the air flow meter. but haven't checked the 02 sensor.... Excuse my ignorance but were abouts is this? do you mean the one in the exhaust???? or is there another in the manifold or something???
yeah the 02 sensor is in the exhaust dump pipe
3 wire sensor
its used for fuel economy and correcting rich mixture
Yeah thats one of the on the list of things to try that we havent got to yet!!!
Thanks paul
Anyone else got any ideas?????
Try swapping computers maybe???? By this i mean to another stock one.
Check your IC pipes again - thats your problem.
Thanks for your 2cents... will check em again tomorrow but we did go over all the joins with soapy water to get some bubbles showing to no avail...... Its starting to s%#t me though so ill try anything!!!!
it wont be the ecu
it doesnt wear out or forget
Yeah just heard a few stories of older cars getting electrical gremlins!!! After all the old 89 r32's aint spring chickens no more!!!!
Thought i would be a waste of time im just trying to think of everything. Funnyly enough me not being a mechanic means the most logical explinations dont always come to my mind first!!!!
thanks again for the input guys!
A classic sign of a faulty O2 sensor is hunting when the car is idling. Judging by your poor fuel economy this would also support a faulty sensor. To test if it is the O2 sensor, simply disconnect the O2 sensor next time the car hunts and see if the idle stabilises.
Hope this helps
Hope this helps
Thanks again guys!
Will be checking all these options tomorrow hopefully. Ill post if anyone wins with their diagnosis.....
keep anymore ideas coming though however stupid!!!!
My money is on a leaking BOV. I bet you have an ATMO bov and it is leaking :happy:
Ha ha... good thought but i dare not partake in such foolishness when the factory one is more than capable and one less thing to get deffected for, also they make enough noise standard i and my car is loud enough as it is!!!
There could be a problem with the the temp sensor f%^ked and then the ecu thinks that it needs to go on to cold start enrichment!!!
It will kill the fuel econ and when hot it will be to rich and be flooding!!
Just a nother place to look.
Thanks again for the idea but i think we can rule that one out as it seems to run the cold start up mode ok and it idles fine in this mode, all be it at about 1100rpm. Then settles down to its hunting on idle shennanigans after the car has warmed up so i think the cold start must be off after that..... Good idea though and one i'll investigate further if the others come up with no results!!!!
:wub:
:happy:
Engine will start and run fine from cold because that is what the sensor is telling the ECU. However, if the sensor is shagged, it continues to tell the ECU that the engine is cold, despite the fact that the engine is actually up to temperature. When the engine is hot, it doesn't run so well when the ECU is dumping sufficient fuel to keep a cold engine running.
It's certainly worthy of consideration in your quest for a resolution to the problem.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
