Hello
After a long think, i decided to go down the path of R34 Smic on the R32 as a suitable cooling upgrade.
Some specs of the side mount intercoolers;
R32
Length: 205mm Height: 190mm Width: 60mm Volume: 2337cm^3
R34
Length: 205mm Height: 220mm Width: 80mm Volume: 3608cm^3
Volume difference of 1271cm^3
Therefore;
R34 smic is 54% larger than the R32 smic (relative to the r32 cooler)
R34 has been stated by others to handle abour 230kw atw
R34 intercooler was cleaned using Petrol and poured out until no black residue came out.
The R34 smic was taken to ReCustoms (Victoria) for installation of smic into my r32.
The R34 smic has a different outlet pipe (which makes it match up with r33 but not r32). Therefore another outlet pipe was welded on the other side to look similar to the stock r32 smic.
Although this still did not make it a direct bolt-on replacement and the pipes needed to be customized slightly. Also the r34 duct was unable to fit and has no air duct (which wouldnt make a larger difference in power really)
Ray from ReCustoms has kindly taken a few photos of the customization of the smic.
Located 2nd Page
Dyno run was made before/after the smic installation;
Mods are;
apexi catback exhaust & apexi airpod.
Thanks goes to Ray from ReCustoms for the installation and patience :O
Highly recommend him for any work on imports.
Cheers
- Patrick :)
https://www.sau.com.au/forums/topic/158811-r34-smic-on-r32-results/
  • Replies 46
Quote from SydneyKid
The R34GTT intercooler was around 68% efficient for cooling at ~200 rwkw. That compares pretty favourably with a standard R32GTR intercooler on the same engine which was 72% efficient at similar power levels. At 200 rwkw and 7,250 rpm, the R34GTT intercooler (and pipework) had 1.5 psi restriction at 1.3 bar. The R32GTR intercooler, with larger pipework and similar power, was 0.75 psi. So even the airflow wasn't too bad.
It will still be pretty prone to Heat Soke compared to a FMIC.
That's the only problem with an upgraded SMIC.
I lost 12kw over 3 runs due to heat soak, and I had a massive fan on full power during the run
-Josh
remapped ecu, the afrs are pretty good, too good for stock ecu
unsure if the comparison is still valid based on this fact
but it is still a valid before and after
i dont think a stock r32 would gain ~20rwkw with the core change
Nice! I've just got one for the cef, pretty much the exact same mods (and I know I have a chiped ecu). Id be happy with half that! Thats tops news.
One question tho, how much boost are you running???
What Ray at ReCustoms said, was that the r32 smic had smaller inlet/outlet holes which would have restricted air flow.
Also that the smic placed in was cleaned out whilst the 13yr old r32 smic would have been clogged up with crap.
Edit;
The car is running on stock boost, dont have any form of boost controller in car so its stock. Ray claimed that there was an increase of 0.5~ due to less restriction.
Stock r32 boost is edit:10psi as indicated in the first graph :O
Edit;
Stock r32 boost is 12psi as indicated in the first graph :O
Haha, thought it was on there somewhere. Thanks tho dude. Thats seriously exactly the same as my car.
heat soak is an issue on a side mount which is why the air guide into the cooler is very important because it rams air through it instead of it taking the easy path around it.
Interestingly it pays to have a slightly smaller inlet to the guide than the face of the core to force more air through it.
It's a good comparison but the average punter shouldn't get carried away with this result as a remapped ecu makes a massive difference. Not just because of the fuel mapping but also the ignition mapping which is what goes a long way towards the quicker boost build and top end power clearly seen on these dyno sheets.
Great effort for your car and something well worth thinking about if your not cahasing big horsepower.
congrats. Must be much better seat of you pants acceleration with such a large jump in power
Amazing result. As others have mentioned its astonishing that not only did it gain ~20rwkw at the top end but its ahead on power over the 32 item right from the basement.
Also, either you typed the dimentions incorrect or you calculated incorrectly as going from the dimentions you posted the 34 item is actually 3608 cubic cms having a larger area of 1271 cubic cms meaning it comes in at over 50% larger in cubic area.
Over 50% greater area is a nice upgrade in anyones language.
ah crud cheers for that.
Didnt double check the data, will fix now :P
Thanks to anDru for supplying me with the smic :P
Took car for a proper drive today (sau cruise) noticed missfires above 3000rpm which occasionally happened before smic upgrade. Mechanic has checked coilpacks several times and indicates they are fine..Could it be linked somehow to the upgraded smic? Will take car for a drive tomorrow and see if the issue is still there...
Cheers
Did RE customs modify the outlet pipe for you? Ive got a r34 sidemount sitting in my bedroom waiting to be modified, the last place i went to get a quote wanted $120 just for moving the outlet to the other side..
If you dont mind me asking what did you pay for the modification and install? Was going to do it myself but there are a lot of things I was going to do myself and have never got around to doing...
Re Customs did all the work, including cutting/welding the outlet pipe + customizing the piping to fit the cooler in. I basically just gave Ray the r34 smic and he did his magic :(
As this was his first time, he may have been unsure how much time/cost it will take in order to fit it. Might be best to give him a call and ask for a quote although i assume the cost will be around the $150-$250 total depending how many dyno runs etc etc.
    • Hey everyone. Is there a way I can get the original window sticker (maroney label) for my 1995 R33 GTST? I doubt I’ll be able to ever get it but it’s worth a shot to ask
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
