Hey fellas, I've got an issue with a hks 2535 which i have just installed on my R32 gtst...everything seems to be in order with no leaks in lines or piping but there seems to be an issue with the boost...it is EXTREMELY laggy and only starts to create positive boost above 3500rpm...which is late even for a rb20...then theres the main problem...after about 5500rpm or so...the boost just skyrockets uncontrollably and doesn't stop rising...i've accidentally hit 1.2 bar on it...the turbo has an adjustable wastegate actuator by the way...can someone shed some light on this please?
https://www.sau.com.au/forums/topic/159128-hks-2535-and-skyrocketing-boost/
check that the actuator is opening all the way... if it is then make sure the wastegate hole on the back of the turbo is big enough to let the gasses escape... the problem here is that your exh gasses arn't escaping in effect creating more boost.. theres a few threads that people have put up with the same problem just have a look around..
also check that your cat isn't blocked
hope this helps :laugh:
Haven't left any of your original vacuum tubes unblocked?
I'd check your tubing setup too to be sure.
I installed my turbo (2535) yesterday with the most basic setup..... just the one tube going from the pressure source (nipple off the intake piping) straight to the actuator.
No boost controller at all yet but will soon.
Where are you dude?
If not too far away we can compare setups.
Working in North Sydney today
3.5 sounds about right to me my 2530 wasnt coming on much earlier than that
and wind the Actuator out to lower the boost alittle anything under .85 though and you'll get worse boost response
as hks actuators are meant to run on .85 bar
why are you worried about hitting 1.2bar, thats where my 25/30 sits at on RB25.
As for skyrocketing pretty normal buddy thats where your car is making peak torque and power, as for coming on a bit late well rb20 with that size HKS unit mmmmm. Get it Dynoed.
nah i think thats about right.. my 2535 on my rb25 starts at about 3000 and realy starts moving by like 35-3700rpm
if you disconnect the wastegate and give her a test real carefuly i think that will show you the fastest it'll boost up so u can compare.. careful thogh cause it'll run at unlimited boost
3500 seems alittle late to me for it to make positive boost but i'll have a look at the rest of the engine again...please keep the suggestions coming fellas...cheers...
I'm definitely not worried about running 1.2-1.3 bar on that turbo as i plan to do that in the future...i'm worried about it now though because my injectors and afm will be maxed out way before that...i have a remap and the car is tuned to only 165rwkw at the moment...with air fuel mixtures spot on...so if the 2535 is running 1.2 bar...i will defninitely be running lean...and thats even before ignition timing is addressed...so thats why...there no point in dynoing it now as i have yet to get the injectors and z32 on yet...and by skyrocketing i mean it doesn't go to 1.2 and sit there...it keeps going and thats why i got worried...
If it keeps going up and up its becasue the exh gasses are not escaping quick enough... start to point the finger at the wastegate, boost controller, turbo and cat.. think about everything that your car needs to let the exhaust gasses escape... if it don't let them escape it wont hold boost.. it'll just keep rising..
i had the same problem and mine turned out to be the wastegate hole on the exh housing of the turbo that needed to be ported out... the hks actuator should only be a 1 bar actuator or less so something is wrong... even try just connecting the vac line from the inlet manifold straight to the wastegate and see how much boost you make.. or the other alternative is to go on the dyno... save you alot of headaches and if it gets dangerously lean they stop the run.. on the road its hard to tell
Thanks mate...that kinda suspected that might be the reason...i'll have to pull it off and have a look...cheers...
dont worry man im in the same situation too, it just keeps on spiking, im thinkn just gettin a stock actuator, not this adjustable crap,and just running a boost controller
let me know if u find a solution and if i got one i'll let u know, coz its annoying the hell outa me
do u have a boost controller connected up?
if so, take it off and connect the hose directly from the compressor housing to the actuator.
My HKS GT2535 does the same on the RB20det with R32 actuator. It goes 11psi roughly and then creeps to around 15psi with no boost controller.
I thought the acuator was stuffed so tried a RB25det one. 7.5 psi and then creeps up around 12 or something LOL. The turbo is coming off soon so i might grind the f**k out on the waste gate area.
You would think HKS found and rectified this problem, c**ts they are.
my personal opinion is that if you can afford a HKS 2535 and the required supporting mods, then you can also afford poncams + adjustable cam gears to make it come onto boost a lot earlier. i wouldn't be surprised if you could get it down 500-800rpm based on my own personal experiences
Thats the way they work!! You put a bigger turbo on, you get more lag, more power, more lag, nothing in the world will stop this from happening!! Cams will give you better mid range and bring boost on a little earlier but not by much.
My RB20 runs a HKS2530 and it behaves exactly how it should, boost is on by 4000rpm and rises to 18-20psi.
Goes like a dream. Maybe you were expecting something else. I have never seen a big power turbo make boost below 1000rpm, that is total crap!!!
The HKS internal wastegates are second to none. If you think you can improve on them good luck!!
You must run a boost controller on these turbos and they need to be dyno tuned. Bleed valve is only $50. Come on now and get serious, I cannot believe some of the rubbish that is posted..
Gee...thanks for the technical lesson...i'm a certified mechanic and mechanical engineer and been involved with turbo cars for 4 years...as if i didn't know that a bigger turbo would cause more lag...when i said positive boost at 3500 (NOT 1000rpm) i meant that the boost gauge would read 0.0bar at 3500 or more...now that i know for a fact is abit late...i'm asking for opinions and suggestions here...i don't need to know that i need a boost controller and i need a dyno tune...so before you try to teach me how about you read your own crap first...i don't NEED to run a boost controller if i don't want to...if you say the hks actuators are second to none then they will hold whatever boost level they're meant to hold properly...
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
