I have been planning to do this for a while as I have the blank screen staring at me all the time, I thought I might be able to put it to good use.
Picked up a little 12v NTCS camera which actually has an infrared function (not expecting too much) but I might be able to get something of a useful out the back of the car (mostly below the tail gate) should also come in handy for reading the number plates of those whom choose to drive too close...
Anyway, jumped right into it at lunch time and plugged that sucker into some power and started working through the extra RCA inputs on the tuner box in the rear left-hand quarter panel, while flicking through the AV1 and AV2 options on the head unit. Absolutely no joy so far, not a thing!
Has anyone had any luck plugging an external source into these inputs? If so any tricks?
I'll try to do a DIY if I ever get it to work!
More questions to come I am sure, like: how do you get video to show while the car is moving?
Cheers
Luke
https://www.sau.com.au/forums/topic/159164-reversing-camera/
  • Replies 98
if it is an RCA wired camera, it should work fine (mostly i havent had a problem with mine in the past)
mount the camera
run the rca to the front of your car.
Hhook up the reverse wire from your headunit to the reverese source ont eh stagea (i have no clue, i still have to hook up mine) prolly for the reverse light wires depending on if they need a negative or positive signal
adn hten plug your RCA into the revers camera input
done!
and if you want it to run al the time
Plus it into the auxiliary plug not the reverse plug, and hook the power wire from the camera to a source that is only on for ignition sources.
Edited by yokotas13
Nick, Camera is NTSC and so is the factory TV/Navi unit, so there should not be any conflict there. You can get PAL cameras to match PAL monitors though so that would be no drama.
Grant, The "factory" TV tuner sits behind the the left hand trim in the cargo space, jammed in behind the 4WD computer. It has an additional set of RCA inputs (I suspect they are inputs) running into the unit. I have tried running through these but have not seen any action yet. I am about to go out and pull out some more trim panels so I can get a better look and see what I can find.
Powering the camera, yep simple as you have mentioned, the other question was related to the head unit and making it think that the car is in park and has the hand break engaged, shouldn't be too hard to sort those connections out but if anyone has them handy that would save a lot of wire probing!
Cheers
Luke
Ok, sorted out which RCA input is the correct one and tested. Got nothing so I plugged the Digital video camera in (wrong format being PAL) and got PAL image on NTSC monitor as expected. So screen/receiver works camera does not. Sending it back tomorrow, note: bloody good reason to buy locally, I can send it back!
More info and results soon I hope...
Cheers
Luke
Ohrly
Mine wasnt all fancy with factory TVs.
i haev a pioneer flip out lol
same i bought a supposed ntsc camera off ebay and it didn't work so i cussed the bloke out, yet to buy another to get to work on the xanavi screen, i have the wireless one i bought mounted near the intercooler with the reciever in the car running to a hdd recorder i bought
Yeah it is going back today, I already have an apology from the seller (sale wasn't through ebay) so hopefully they can send me one that works!
sorry can't help with the detail.
But I had a camera put on the tailgate, it is brilliant. I use it all the time to line up the trailer over the towbar, makes it a 1 person job.
Also you can get super close to the car behind when parking. These cameras are brilliant!
Hi Duncan,
Where is the camera mounted on your tailgate? That is something I still need to decide, was thinking about mounting it inside to keep it out of reach but will really depend on what sort of image/angel I can get from any given mounting point.
Cheers
Luke
Mine is under the handle, just to the left to avoid the openy bit. Its out of the weather, and still gives a good field of view
I was looking at the back of mine last week and decided on using that same spot, but on the RHS (driver's side), and angled just a little towards the kerb.
Pointless now, because I went and bought a standard single-DIN head unit to replace the factory unit - I was so sick of the shitty radio reception and skipping CD player... Maybe further down the line I'll get a head unit with a display.
New Camera has arrived, it works and has been installed.
Now I really need to know which wires to earth/bridge/power to override the screen switching off once you either release the park brake, or move out of "Park"!!!
Have had a bit of a poke around with the multi-meter on the "screen" loom but the signal could be coming from the tuner unit, or I was thinking even the dash lights??? If anyone has overcome this issue I would love to know how you did it!
Cheers
Luke
ok, got some info, see if this helps:
see pic;
DISPLAY AND NAVI
32 Reverse lamp
33 Parking brake
34 foot brake
35 inhibitor (something to do with auto ??)
25 speed meter
my guess is track down 33, which i guess is on the back of navi unit or radio, check if it is earthed when park brake on/off and cut/earth appropriately. the unit on the upper right of pic is the tv tuner in the back.
Edited by chook
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
