pretty stupid thread but don't know where else to ask.
drove past a very nice mercedes benz this arvo but didn't get a look at the badge on the rear.
its a 2-door and both rear quarter windows can be opened aswell. size wise it looked as big as a soarer. had big square headlights and squarish taillights aswell. dropped on big amg rims it looked nice as :(
anyone know what model merc i'm talking about? i think i'm in love :(
praying to god its one of the cheaper model mercs :( .......bah there are no cheap mercs :rofl:
EDIT: oops thought this was the general section :)
Edited by R-SPEC
https://www.sau.com.au/forums/topic/159406-what-merc-is-this/
anyone know what model merc i'm talking about? i think i'm in love :)
praying to god its one of the cheaper model mercs :( .......bah there are no cheap mercs :(
EDIT: oops thought this was the general section :(
What year you talking about> Sounds something like a 560sec google em see if its what ya talking about. Big two doors 5.6lt v8 rear windows can go down etc. :rofl:
only ones i can think of off the top of my head that are as big as a soarer and have old square lights and are newer then the old 560SECs are the 320CE, CLK (altho thats probably no where near the length of a soarer) and SL500 Hard top (which is one of my favourites)
woot! 320CE :sorcerer:
could only find a topless version pics on google but that's the one :P
just carsales.com'ed it.....its too expensive :laugh: back to japs it is :laugh:
always loved the 500sl one of my favourite cars ever. :rofl:
cheers
The car you are talking about is a CL - the 2-door S-Class.
One of these:
Drug dealing at it's finest.
If you're the big dick on the block - you drive the CL63 AMG.
If you're his boss, you drive the Brabus version.
Clicky - http://stadium.weblogsinc.com/autoblog/hir.../brabuscl02.jpg
MY GOD!!! the black 1 (far right) :O
:P:):D:wub:
thats the 320ce yea? definately going on the list of the "must buy cars" ;)
personally that's one of the best looking cars i ever seen. and all they need is some nice big rims and lowering/bags :wub:
Edited by R-SPEC
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
