  • Replies 194
I'm in.
I'll see you there Ash. :)
good to see cubes...
just trying to work out the numbers of who's coming.
so i have added a list to my first post.
everyone have a look and let me know if you or freinds want to be added etc
at a guess we are heading towards 30 rb's..
that will be a sight to remember..
Edited by dangerman4
So you guys from up here ( clean-gtst, grim and anyone else up here ) Do you want to cruise in together and back? We will be doing the hard yards so we may aswell do it together!
yeah lee sounds good, meet up down this end of town then meet the guy's at mile end then down south. if it's a 250km drive from there it's gonna be over 300 for us. But anything to see a massive line of line's cruisin on the open road and especially for a good cause :D
Id be keen to meet up and cruise down together, just need to work out some times and where to meet and ill be there!
Im there. Meet points like 2 minutes from my house so im in. :rofl:
Will it be dark by the time the cruise is over, might have to get my headlight wiring fixed, push the brake pedal and the headlight and dash lights light up LOL
For those everywhere not near the official meeting point.........ive noticed that the etsa car park is still available to get to
Meet at ETSA car park 11 sharp, gives us like an hour to wait, meet and great and then cruise together to the official spot further away
what do u guys/gals think?
Is the 250 odd kms we're covering just one way?
no its approx 250 kays total.
it may be closer to 300 kays for you guys out the other side of the city,
but that will depend on your final route home.
for less then a tank of fuel it will certainly be one to remember.
as far as time frame goes i would assume we should be finished by around 5 o'clock
any other questions let me know
cheers
Darren
Yeah I'm keen to meet up and cruise down south to the next meet point. Should be a good cruise :)
Just got an email from my Photographer buddy. HE'S IN!! Should be able to get some awesome pics.
Edited by CleanGTS-t
What's weather like? I'd like to go but my drivers side window is stuck in the downright position and this could pose a problem if it starts pelting or even spitting with rain. I'd like to say I'm in depending on weather.
Yeah I'm keen to meet up and cruise down south to the next meet point. Should be a good cruise :(
If we have to be at etsa park around 11 and at the final meet point at 1, then im thinkn us guys out north should aim to meet say at Munno Para Maccas at say around 10am? What do you think dave and lee and anyone else down our way?
We are going to a christining at 1pm. However, we would like to meet up, if I may have a PM of the organisers to call after we are finished to meet up that would be great. Thanks, BB
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
