wondering when i get my FMIC if i should hack into the front bar for more cooling exposure or just leave it. if i go ahead and attepmt it i would want to make sure it sweet and no dodgy cut marks ect..
can anyone post pics of how there front mount looks with the series one front bar??? i.e stock or cut into.
(professionally done or DIY)
thanks
jake
https://www.sau.com.au/forums/topic/159558-series-1-cooler-cuts/
yeah i know but i was refering to actual cutting for visual appearence. i think ive seen a pic on a series 1 with no visual bar changes (from the outside..i know you would have to cut it on the inside to fit it in.) if that makes sense. so looking for S1 front bars with the cooler fully installed pics if anyone..
thanks
jake
Edited by jake33
ha yeah was thinking somthing in between.
exposed but not overally exposed. kinda like a woman in her underwear rather that completly naked. ..pfft!
pics anyone??
cheers
Edited by jake33
ah shit! sorry i do have an mspec front bar. sorry guys. yeah thats what i was considering.. removing that middle section in the bar. just unsure if i should get a shop to do it or go the hack on it myself. thanks for the pic. keep em comming if anyones got anymore.
thanks
jake
Here whats involved ....easy .....do it yourself, cut it, fill it, sand it, paint it, fit it.......Job done.
Vent fitted where the indicators / spots were....or leave them and add vents elsewhere...depends on your laws on car lighting.
Edited by Allkiller
You gotta get air to that intercooler....more the better
The other thing thats cool is a spring hinged Number plate that will swing back out of the way due to air pressure at speed.... and then return to normal position as you slow down......trick.
Edited by Allkiller
Bah, the intercooler is only really a heat sink and that's all you can expect from a hybrid special. Cutting out the front is really only prolonging the inevitable (heat soak).
I intend to use water/meth injection in the near future to combat this. Although I'd still like to cut the bar out, as I'm seeing higher engine temps due to the lack of air flow to the radiator.
Then why fit one at all ??
Of course the more air you get to a air cooler will work....hiding it behind the front bar, is like opening all your windows in a drag race.
It is a heat sync, but this is cooled by air, hence the position of it, cover it and its useless.
Water injection is.....another source to remove heat and increase combustion, but works great in conjunction with a FMICs.
The cooler would still be effective for a while even if it was fully enclosed. The problem is the cooler cannot dissipate heat as fast as it conducts it. So removing front the middle section would have minimal gains.
I'd say even with my setup the majority of the airflow would still find its way through.
thanks
jake
DIY
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
