wondering when i get my FMIC if i should hack into the front bar for more cooling exposure or just leave it. if i go ahead and attepmt it i would want to make sure it sweet and no dodgy cut marks ect..
can anyone post pics of how there front mount looks with the series one front bar??? i.e stock or cut into.
(professionally done or DIY)
thanks
jake
https://www.sau.com.au/forums/topic/159558-series-1-cooler-cuts/
yeah i know but i was refering to actual cutting for visual appearence. i think ive seen a pic on a series 1 with no visual bar changes (from the outside..i know you would have to cut it on the inside to fit it in.) if that makes sense. so looking for S1 front bars with the cooler fully installed pics if anyone..
thanks
jake
Edited by jake33
ha yeah was thinking somthing in between.
exposed but not overally exposed. kinda like a woman in her underwear rather that completly naked. ..pfft!
pics anyone??
cheers
Edited by jake33
ah shit! sorry i do have an mspec front bar. sorry guys. yeah thats what i was considering.. removing that middle section in the bar. just unsure if i should get a shop to do it or go the hack on it myself. thanks for the pic. keep em comming if anyones got anymore.
thanks
jake
Here whats involved ....easy .....do it yourself, cut it, fill it, sand it, paint it, fit it.......Job done.
Vent fitted where the indicators / spots were....or leave them and add vents elsewhere...depends on your laws on car lighting.
Edited by Allkiller
You gotta get air to that intercooler....more the better
The other thing thats cool is a spring hinged Number plate that will swing back out of the way due to air pressure at speed.... and then return to normal position as you slow down......trick.
Edited by Allkiller
Bah, the intercooler is only really a heat sink and that's all you can expect from a hybrid special. Cutting out the front is really only prolonging the inevitable (heat soak).
I intend to use water/meth injection in the near future to combat this. Although I'd still like to cut the bar out, as I'm seeing higher engine temps due to the lack of air flow to the radiator.
Then why fit one at all ??
Of course the more air you get to a air cooler will work....hiding it behind the front bar, is like opening all your windows in a drag race.
It is a heat sync, but this is cooled by air, hence the position of it, cover it and its useless.
Water injection is.....another source to remove heat and increase combustion, but works great in conjunction with a FMICs.
The cooler would still be effective for a while even if it was fully enclosed. The problem is the cooler cannot dissipate heat as fast as it conducts it. So removing front the middle section would have minimal gains.
I'd say even with my setup the majority of the airflow would still find its way through.
thanks
jake
DIY
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
