hi guys it has cum time to go big on the brakes. i have a 540awhp r33 gtr soon to be 600awhp and want to upgrade my brakes. have looked at just japs big wp brakes and nengun for the big trust grex systems both 6piston front and 4 rear with 355 front disk and 330 rear(not interested in the g4 brakes) will cost around the 6-7 mark installed does any 1 have big brakes that there recommend ap or endless or alcon just want the best brakes to pull me up when i need to stop... any info would be great
https://www.sau.com.au/forums/topic/159624-big-brake-upgrade-for-gtr/
  • Replies 75
Posted Images
I assume you are aware that you will not be able to use your current (standard) brake master cylinder in conjunction with any decent brake upgrade. The hydraulic ratios will be wrong, in addition to the leverage and movement ratios of the pedal and consequently you will most likely end up with one or more of the following;
1. A long brake pedal (excessive motion)
2. A heavy brake pedal (excessive force required)
3. An imbalance in the front to rear braking distribution (premature front or rear brake lock up)
I see so many cars that have had extensive/expensive calliper and rotor upgrades, that stop worse than standard. Adds up to a big waste of money, for no benefit.
:( cheers :O
:D cheers :D
Very informative post...but...whats the point of it if you don't tell him how to overcome the issues you have addressed. Id like to know as well.
I thought the answer was obvious, get the right sized master cylinders as recommended by the calliper manufacturer. I say "cylinders" (plural) because it is most unlikely that you will find a tandem master cylinder that will properly match any decent calliper upgrades.
:D cheers :D
I have found ppl tend to make a simple topic more complex then it needs to be.
Sure, run out and spend lots of money on bog front and rear kits...but all you need is therma capacity. Std gear works pretty well, but has its limits. The great gear works better then the good gear which works better then the std gear. But i dont think the difference in actuall performance is all that dramatic. The feel yes, but performance no.
. SO you have std Brembo rears, then make sure the rotors are healthy and lines and pads ok. If you have 17" rims grab some 343/355x36mm rotors and run them with CP5555 AP Calipers. If you have 18" wheels then look at running 365x36mm rotors.
Relatively cheap upgrade and works well with std rear calipers/rotors. Just need to play with the rear pad to suit the front pad you are running.
Its all the thermal capacity you will need from a street/track car. Unless you are doing more then 10laps at a time and its actual racing where you cant afford to back off for a single lap to help temps get back under control before running off into the sunset :D
Putting a pedal box in a road car is massive overkill in my eyes...cool, yes. But just be prepared to spend double on what you spent on the setup paying someone to dial it all in and getting it to work as well as the std setup....development costs money. If we are talking about a race car then save your money and strip weight out of the car. It will be cheaper, help smaller brakes live and will actually decrease stopping distances. :D
good post Roy, have you been able to obtain well made caliper offset brackets.
Gary...You answered my question by elaborating in your next post...thank you. Now here's two more...what is the ideal hydraulic ratio? how is it calculated?
The porsche upgrade seems to be a good one , they are monoblock calipers ! john at uas sells them as a upgrade for gtr .
For offsetting what caliper and rotor? There was someone floating around late last year doing them. A few ppl bought some, though i have not heard how they have gne with them.
I have had moine on/off so much of late...it is a budget fix that works well. But the more i look at it them the more i am tempted to just bite the bullet and get 4 pot APs on 330-324mm rotors. They are hard to go past for value and performance. But there is always the offset brackets for the cheaper option again. Someone is about to trial some R32 GTR calipers on 340mm rotors. I was going to do it, but honestly im sick of wasting money trilaling stuff because im curious...my car is still slow. Any money i spend from now on has to make my car go quicker :D
good point. brakes only slow you down.
the porsche 6 spots are a good price at about 800 per side, but you need to add lines, discs, pads and caliper mounting brackets
danoz, not sure why you don't like the g4s, what problem did you have when you tried them?
also....are you having brake problems already or do you think the extra 60kw is going to kill your current ones.
I've got the Porsche 6 pots on my car, i'm very happy with them. But I do need a bigger master cylinder, I'm hoping the R33 one will boost it enough so the pedel isn't so long after some knock off.
come on guys brake manufactures dont make brake for gtrs that need all these master cylinders to be upgraded or there would sell the master cyliders aswell alot of guys running big brakes say its a mazing difference or there would go spend 7grand on a set up i rang greedy today there run there big brake kits on there gtrs all day on the street and the track for years with no problems at all.
tracker... i just dont like the look and the length that g4 have been in the game i no people using them say there look fine but time will tell. there are propbly a good thing i just want quillty proven race parts
I've got a question, I've got brembo f50's on the front and standard rears on a 90 model 32 ..
i'm in need to get new rotors. they are a two peice hat design and have shown signs of hairline cracks. now i'd say they are fine for the street.
but i want to go to the track on april!
where can i get rotors in sydney for them? what other info will i have to provide to help you guys with my search?
Cheers
this may seem like a dumb question, but how and where did you ring Greddy? I have spoken to a few of their guys in japan, but the only ones that could speak english were mostly just sales people, all the guys with the technical knowledge speak japanese only (unless you speak japanese?).
my workshop that looks after my cars deal directly with japan. the question was ask and anwsered the sales guy went and asked the techs
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
