I was looking at ebay turbos before I said, "f*kit im gonna get a garret and blow a few thou" and I tell you wat GARRETT/HKS > HIFLOW > KKR > REST OF CHINESE SHIT. Never lookin back. Garrett GT3076R ftw.
Edited by Pauly33GTS-t
  • Replies 40
i asked this question to ppl who already bought turbos off this one seller. most of them right up positive feedback because they recieved not because they had it installed. anyways i emailed a few ppl and most of them said that the turbos are good for low boost applications (around 7-9psi) and that they are cheap chinese copies.
i would stay away because last thing you want is one of these blowing up and then having to spend twice as much getting a new turbo and fixing any problems the blown turbo caused.
i had on a super t70 work awsome not on low boost eithre running 22psi after 2 year done a seal so i got it rebuilt but after the rebuild the turbo fail 4 month later on 12 psi the ppl that rebuilt it wont take responability for the rebuild i brought this turbo 3 years ago work fine untill someone rebuilt it i am now goin through consumer affiars so the ppl that rebuilt it take responabilty for it
i have seen t70s with a totally diffrent built such bad quality now i must have being lucky
so really its a lucky dip i now have a garrett 35/40 and i know now thats wat ill be sticking with
no point taking the risk
I asked the guys at JustJap.
They said there turbos are made by Ottomoto, same company that makes the KKR turbos.
They are basically the KKR's with different branding.
so does this make them better than the "ebay chinese copy" turbos that everyone brands most turbos with?
I believe the KKR otomoto ones are different to these ebay chinese copies.
They are nasty and cost the retailer stuff all for the T70 and other copies. From what ive seen of availablility of chinses turbos the KKR is a different beast and more expensive from the wholesaler.
Chinese + moving parts = Steer clear.....
I was going to try and challenge this with an example of a chinese made item with moving parts that is exceptional, but i cant think of any thing? lol :S
Thunbps up for the Intercoolers,radiators and some of their other parts tho lol
The KKR's are made in China from what i can gather.
Not everything out of China is neccesarily bad you know. People would be surprised to see what parts they might buy that were actually made thier and you wouldnt even pick it as the quality is good. Aust businesses wouldnt be selling stuff that would potentially bring them undone, thats just silly.
Its just the knock-off products you need to be wary off from the "unheard of" places over Ebay etc etc.
The actual *legit* decent stuff from China isnt all that bad. Its just there is a lot of crap bringing down the names of the few that are reasonably decent.
In High performance Imports Mag, they said KKR was a Korean turbo and supply Volkswagens and other cars with their turbos from memory. Apparently the KKR turbos are pretty reliable and produce good power, they're just a bitch to fit.
I'm looking at getting a turo soon too. Anyone on here bought and fitted a hypergear turbo? they are also cheap but are from Korea
also just some other notes in regards to cheap ebay turbos / cheap seller turbo's
more often that not there are some key differences
- wierd flanges or dump patterns (kkr, monsta t70 etc i dont think mate at all to standard parts and need their own bits)
- plain bearing, journal bearing (majority of the cheapies aren't ball bearing)
- oil cooled only (usually the cheapies are oil cooled only)
- lack of compressor map / details available (usually monsta STAGE 3 hiflow super wheel blah blah type jargon, no real reference to compressor trim,blade type)
but they are exactly that, a cheap alternative. im not saying the dont work but there are extra things you should be aware of and need to know if using them. some need extensive modificaitons, some dont need much at all. some require extensive knowledge for fitmet (oil line changes to remove BB restrictor) and some have extra "gotcha's" when using them over the standard turbo (non BB unit and instant car off risks bearing failure)
so sure its a $650 turbo thats capable of 550hp but look at the overall plan and solution and see what you are really getting.
with an off the shelf garrett unit you can ring gcg in sydney, discuss flange/dump options, manifolds, you can ask for compressor maps (no guess work) and work out the optimum solution, but that also comes at a price. a price for reliability, knowledge, customer support (compressor maps, blade options, housing options etc) and help
great a new turbo that lasts only 2 years! Sounds like a peice of crap.
The owner of HPI is also the owner of Ottomoto/KKR so that opinion may be a bit biased
Of course its bias. I totally agree.
Ben Ellis (ottomoto/HPI) wouldnt slander your own product now would he hehe :sorcerer:
Dont trust everything you read, especially magazines that have vested interests
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
