NAME: JESSE OR JEZ ^_^
CARS: R32 4DOOR GTS-T SILVER, PULSAR N15 HATCHBACK
MSN: [email protected]
plates: 32JEZ, 199DML
pictures: www.sql-gaming.com/user/JeZ/
Edited by 32JEZ
CAR:R33 GTS-T
Dont have MSN will get it one day when i get round to it.
Always up for a cruise and meeting others when i can - which isnt often only get out once or twice a month.
Edited by subzeroR33
hey all, im adam from briz north side, i drive a black r32 gtst m-spec with white nismo LMGT-1 rims. basic mods at this point in time, but the car runs great and heaps of fun to drive on my day off. give me a chalk if ya see me round, also forest lakes area where i work. later adam.
Type-m :P
You would get flammed in the general section //wastelands if you were caught saying that... dont let Dan The Man see you typing that.. he will get the ban stick out :sick:
welcome though.. if i see ya ill flash my lights at you and hopefully not run you off the road...
on second thoughts.. i might just beep
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
