Nick has seen my car yet there is not a little bit of him in it. Therefore his quote is invalid.
2 things:
1st thing: I didn't say it, I quoted John Mayer
2nd thing: I made the quote up so your point is invalid lol
2 things:
So you made the quote thus it is your quote even if you attributed it to someone else.
Hey people
im jordan been in and outta here readin wat people have say n loving it so helpful. Iv gotta blue 32.4, be chasing a rb25det s1 in mint condition soon if any one can.help?? Otherwise a mate n i are keen as mustard on some cruises and meets around the goldy and brissy
cheers everybody
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
